RV.Net Open Roads Forum: Tech Issues: Flipping Axle
 > Flipping Axle
BFL13
Victoria, BC
Posted: 01/13/20 07:26am Link  |  Quote  |  Print  |  Notify Moderator
Our first 5er had to be "flipped". It had Dexter axles mounted on a sort of bogie that was welded to the frame. The fix was to unweld the bogie, put in spacer bars as shims welded to the frame and weld the bogie onto that.
That way it preserved the axle alignments and the whole assembly. Another thing to mention was they had to extend the wires to the brakes which were too short after the flip.
That got the trailer height close enough that then adjusting the pin bracket and the hitch bracket was enough to level the trailer. Using taller tires was not an option due to wheel well clearance and the spacing between tires front and back.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
Jethroish
Scottsburg, IN
Posted: 01/13/20 07:39am Link  |  Quote  |  Print  |  Notify Moderator
Had 2 shackle links break. Turns out, I can get new links that are 3/4 inch shorter than original. Will lift 3/4 an inch +/-.
Don't let your work become your life.
2018 RAM 3500 Dually 4x4 crew cab,
2015 Shadow Select 4 horse LQ w/slide out
2021 Jayco JayFlight SLX 264BH
Cummins12V98
on the road
Posted: 01/13/20 08:46am Link  |  Quote  |  Print  |  Notify Moderator
May be better off adding risers to the bottom of the frame? I know different suspension.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
smarty
new mexico
Posted: 01/13/20 08:58am Link  |  Quote  |  Print  |  Notify Moderator
I just purchased a 32' 1970 airstream and plan on flipping it in this same manner. Has anyone had any experience with this? Is it doable? Need more ground clearance so I can hunt with the renovated rig.
Chum lee
Albuquerque, NM
Posted: 01/13/20 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
TakingThe5th wrote:
FYI-do not use cinder blocks on this project. They can crumble. Use boards.
I would not hesitate to use 8 x 8 x 16 cinder blocks on a temporary basis long as they are 2,000 psi or better, monolithic, oriented/stacked properly, (cells vertical) and you use 2 x 8 boards "on top, and, if necessary on the bottom" of the blocks before putting any load on the blocks. Don't stack the blocks more than 2 blocks high. Putting point loads on concrete (cinder blocks) is a horrible idea and will cause early failure. The soft wood distributes the loads over the full bearing surface of the block. Think about it. I've personally designed/built block retaining walls well over 30' high. Not a problem as long as there are no point loads and you handle the lateral/overturning moments. That said, if you can't do that with confidence, just use jack stands or solid wood blocks.
Chum lee
BarabooBob
Baraboo, WI
Posted: 01/13/20 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
I would never use any cinder block to support weight such a car or trailer. In high school we had a shop teacher do a demonstration. He placed a cinder block on the ground under a car, placed a hydraulic jack on top of the block and jacked the car up about 3 inches. He then tapped the cinder block with a very light weight hammer and the block shattered.
There is a reason that I have high end jack stands in my garage and will not ever use concrete blocks.
I will not apply for a Darwin Award.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
ScottG
Bothell Wa.
Posted: 01/13/20 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
As a dumb kid, I tried the cinder block thing and it exploded. Fortunately there was no harm or injury but I learned my lesson.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 01/14/20 03:57am Link  |  Quote  |  Print  |  Notify Moderator
Flipped axles on my FW in our driveway using cribbing.
Only use cribbing on a job where you have to go underneath the frame. Anything else can fail.
  • 2019 Grand Design 29TBS (had a Winnebago and 3x Jayco owner)
  • 2016 F-150 3.5L MaxTow (had Ram 2500 CTD, Dodge Durango)
  • 130W solar and 2005 Honda EU2000i twins that just won't quit
drsteve
Michigan
Posted: 01/14/20 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Working on a buddy's car years ago, he had it on cinder blocks. While we were standing there admiring our handiwork, one of the blocks just disintegrated.
Just say no to cinder blocks.
1991 Palomino Filly PUP
trail-explorer
NM
Posted: 01/15/20 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
I've done a few "spring over axle" conversions. Flipping the axle is a no go. If you flip the axle, the tires rotate the wrong direction and then the brakes won't work
Bob
 > Flipping Axle
