RV.Net Open Roads Forum: How to remove/prevent standing water at campsite???
 > How to remove/prevent standing water at campsite???
Page of 7
Posted: 09/21/20 12:53am Link  |  Quote  |  Print  |  Notify Moderator
Looks like a beautiful site. Just looked at the pictures.
Agree, you can’t fill in appreciably against the trunks of the trees unless you left tree wells.
However with none of us knowing the entire topography of the area or other challenges you have, it’s almost impossible solve your problem and generic suggestions are all you’ll get.
Furthermore, unless you know the ground type and groundwater levels, many of these suggestions may be ineffective as well.
You need to find out what you CAN do and then what will work of those ideas.
JRscooby
Indepmo
Posted: 09/21/20 03:28am Link  |  Quote  |  Print  |  Notify Moderator
Dtank wrote:
darleyhavidson wrote:
I am not installing/using a sump pump. If I lived there permanently, that course of action might be more feasible.
From where I sit you have limited options;
1)Witch about it.
2)Move
3)Divert the water before it drains to your site
4)Fill area to raise grade.
5)Install a gravity flow drainage system
6)Pump water out of area.
1 is what you want to stop. 2&4 You don't want to do. 3&5 a lot of work, and much in areas you don't control.
6, once the bucket is in place, and water collects rent a 2 inch trash pump for a couple of hours. Your feet get wet on the way to get pump, and while you put suction hose in, but water is soon gone.
7) If all the suggestions for a solution are "non starters" - just call it *Mission Impossible* - and try your best to enjoy your lake!
Years ago I contracted to dig the hole for a company putting in a swimming pool. Was finished except the paperwork and we had a cloudburst. Homeowners, contractor and I took shelter in carport. "Look at all that water running into the hole" The woman asked what do we do now? The "educated donkey" in me said Stock it. She I don't want a pond in the yard! Why not? you can swim in a pond but you can't fish in a swimming pool
Page of 7
