RV.Net Open Roads Forum: How to remove/prevent standing water at campsite???
 > How to remove/prevent standing water at campsite???
Page of 7
ScottG
Bothell Wa.
Posted: 07/09/18 11:46am Link  |  Quote  |  Print  |  Notify Moderator
Another vote for gravel.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
time2roll
Posted: 07/09/18 11:55am Link  |  Quote  |  Print  |  Notify Moderator
Fill it, cover it or drain it.
675w Solar pictures back up
cyntdon2010
Jacksonville, Florida
Posted: 07/09/18 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
X3
SIMPLE
2010 lacrosse T.T 318 bhs 34 ft,blue ox-tow bar,2005 FORD F-150 larait super crew,Firestone ready rite-air bags lift kit
darleyhavidson
North Dakota
Posted: 07/09/18 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the suggestions. I would rather not use gravel as we planted grass in that area and it took off real nicely. Might have to use more soil as filler and see if that helps.
dh
valhalla360
No paticular place.
Posted: 07/09/18 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
Your RV does have wheels doesn't it?
Tell the owner, that he needs to put you in a spot that isn't flooded or you will drive on down the road.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
DougE
New Braunfels, Texas USA
Posted: 07/09/18 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
Build a French drain to a lower area. Cut a trench with a slight slope to the lower area. Put in 6" to 12" of gravel. Place some newspaper on top of the gravel to avoid it silting up. Cover with top soil. Your grass will grow back and the site will be self-draining.
2005 Leisure Sprinter Class B/2015 Honda CTX700
2gypsies
Enjoying the West!
Posted: 07/09/18 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know anything about seasonal sites but it seems like since you don't own that property you shouldn't undertake a project of diverting water on your own. I'd contact the owner and see what he can do to help.
Full-Timed for 16 Years
.... Back in S&B Again
Traveled 8 yr in a 40' 2004 Newmar Dutch Star Motorhome
& 8 yr in a 33' Travel Supreme 5th Wheel
ppine
Northern Nevada
Posted: 07/10/18 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Gravel is not so good to walk on or camp on. I would use road base, sand or decomposed granite way before gravel.
Alfred622
Rochester, MN
Posted: 07/10/18 08:28am Link  |  Quote  |  Print  |  Notify Moderator
If none of the other suggestions work for you (and they are good suggestions), one other idea is to drop a couple of 2x4's across the low area and nail some 1x2's across the top. That will make a wood open deck that will let some light to the grass underneath but will let you walk across the bog and not get wet. When you don't need it any more, you have firewood. Total investment would be under $10 so it is not an expensive solution.
Alfred
2005 Sightseer with Workhorse, ReadyBrute Elite towing 2003 Honda CRV
Map below shows states where we actually camped.....
darleyhavidson
North Dakota
Posted: 09/15/20 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
Here are a few links to pictures of the water issue I am still dealing with. Any advice would be appreciated.
https://link.shutterfly.com/rVai4SFkO9
https://link.shutterfly.com/UJ8SsoRkO9
https://link.shutterfly.com/b3KQAoVkO9
Page of 7
