RV.Net Open Roads Forum: Class A Motorhomes: Replaced my Generator ... Help
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > Replaced my Generator ... Help
Page of 7
Jsejmz09
Greencastle, pa
Posted: 07/10/18 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
The Onan finally died. (has been nothing but trouble). I replaced it with a a open frame generator from Lowes for under 500. But I think I may have a heat problem. I ran it for about 1/2 hour and the compartment was very hot, even tho it is open on the bottom. Should I rig a exhaust fan pulling the air out, or in this case down? Has anyone else done this, I can't be the first to be cheap.
rk911
Wheaton IL
Posted: 07/10/18 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
heat rises.
'73,
rich, n9dko
Every retired man needs three things....a good truck, a good dog and a working wife
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
skiatom
Oklahoma
Posted: 07/10/18 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
I have an Onan. I had a huge flywheel type fan tha blows the heat downwards. Maybe you could somehow rig a major cfm electric radiator fan to blow the heat out.
Ranger Smith
Wherever the rig is parked
Posted: 07/10/18 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
Those generators are designed to run in open air . . . Not closed in like that. Need some kind of fan.
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6600 with Maestro, Icom 7610, and Icom 7100
Steve and Joy
2012 Winnebago Tour 42JD . . . 2016 Ram 1500 4x4 Toad
Cooper ... The Doodle,
Baby and Kissie the new Chihuahuas and Lucy the New Biewere Yorkie
wildmanbaker
Kennewick, Washington
Posted: 07/10/18 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
Greg, you may be whipping a dying horse, or soon to burn up. The Onan had a complete enclosure and a fan the ran off the engine, to cool it. It was designed to be in an enclosure to begin with. You really need a generator that was designed for use in an RV enclosure.
Wildmanbaker
Jim@HiTek
Gresham, OR, USA
Posted: 07/10/18 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
Visit any auto junk yard nearby and pick up a 12V radiator fan. If necessary, you can wire it with an Off/On thermal disk to automate it's turn on and off. They're not expensive. Might have to get creative where to put it in your generator space, but you should measure any potential spaces you have before picking one up.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
chuckftboy
Fleming Island, Florida
Posted: 07/10/18 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
There is a reason a $500 generator costs so much less than an Onan. I doubt a fan can move enough air in a compartment to keep it running.
2015 HR Ambassador 38DB 340 ISB
2006 Jeep TJ and 2011 Chevy Traverse Tows
Jim@HiTek
Gresham, OR, USA
Posted: 07/10/18 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
OP already changed out his Onan for something else. There's no going back most likely. So, the challenge is to help him come up with something that will work to cool off his brand new generator.
I figure if a rad fan will keep my engine coolant below 1/2 temp mark on the gage, even with the A/C running and with it being 100F out, there's probably a fan assembly out there in a junk yard somewhere that will keep his generator cool.
Let's see what other ideas we can come up with. 'Cus that's all I got.
2oldman
Salton Sea
Posted: 07/10/18 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
You also have a noise problem.
Isaac-1
SW Louisiana
Posted: 07/10/18 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah that too, I can't see this being very popular around the campground.
Page of 7
