RV.Net Open Roads Forum: Tech Issues: How perfectly should my Onan run?
 > How perfectly should my Onan run?
Straylight
The Road
Posted: 07/12/18 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
Chum lee wrote:
I don't mean to be a smart *ss but are you having any problems running equipment with the genny? Any problems starting it, reaching maximum output, excess fuel/oil consumption, exhaust smoke, overheating, noise, spark plug fouling, etc? I have the same unit and I can't hear yours, but, mine does change speeds/voltage slightly depending on load, altitude, temperature, etc. It has never failed to do what I ask it to do. Years ago I learned not to try to fix problems I don't have and I spend my time resolving the ones I do. Could you be expecting too much? Just asking. You have a very popular genny. It might be worthwhile to listen to others and see what they sound like before you condemn yours.
Chum lee
I don't think this is a smart*ss point at all! It's really why I'm here: The thing runs, never pops down below 57 hz for more than a half second, and powers my A/C and microwave well enough; I'm curious if this is just how it's gonna be or if I should keep pushing it.
re: other comments, let me read it back to you guys:
  • Two main suspects: Poor carburetion or poor governor springs.
  • If it's the carburetor, I'll likely need to replace it, given that the interventions so far haven't yet fixed it (I tried carb cleaner and air, then a very Berrymans-heavy external gas tank over several days, then an ultrasonic bath). If I really wanted to, I could poke around in the carb with strands of small-gauge copper wire, but even that wouldn't guarantee anything.
  • If it's the springs, I can replace them and redo the governor calibration, and I should see improvement.
I'm gonna do the following:
  • Drop by the Cummins guys tomorrow and pick up the two governor springs (the main spring, short and fat, and the spring parallel to the throttle linkage, long and narrow) in addition to an air filter (worth a shot). Install same. I'm a little wary about how much of a pain it's gonna be to replace that main governor spring by reaching back into the genset from the access panel, still mounted under the rig. Any advice there?
  • Redo governor calibration by: adjusting speed screw at idle to 62-64hz, checking that pulling throttle tang against stop screw drops hertz to steady ~55hz and genset doesn't die, applying heavy load and observing hunting pattern, adjusting sensitivity screw counter-clockwise by one or two turns to decrease sensitivity to eliminate any hunting condition, re-adjusting speed screw in light of new sensitivity screw position, lather rinse repeat until I observe a drop to 58-60hz under load with no hunting condition.
  • And if none of that works I'm either gonna close the access panel and live with it, or I'm gonna put a new carburetor in it.
Quick edit: I'm also going to check the choke linkage and housing and starting-temperature setting. Possible something's wonky there, considering bad behavior on startup that subsequently evens out considerably after the unit (and thus the exhaust-heated thermostatic choke) has heated up.
* This post was edited 07/12/18 04:32pm by Straylight *
azrving
Oatman
Posted: 07/12/18 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Read the plug. If you want to live with it as is and you see that the plug is more of a brown color you are pretty safe. If you were to see a black color it's an indication of a rich condition. Rich conditions can cause cylinder wash and fuel dilution. A white color could be on the lean side and cause higher temps and exhaust valve burning.
Straylight
The Road
Posted: 07/12/18 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
I'll pull the spark plug at your recommendation, too. Will report back. Might photograph everything, just for other people reading this thread for their gens in 2020 and beyond.
Straylight
The Road
Posted: 07/14/18 10:08am Link  |  Quote  |  Print  |  Notify Moderator
After taking all the other interventions I could, I swapped out the carburetor with a new one.
The singing of angels, gentlemen: A high and far-off song of joy, ten thousand thousand voices joined in ecstasy. It spins like a top, ticks like a sewing machine, purrs like a cat.
I honestly sort of eyeballed the speed and sensitivity after I put in the new carb, but even with "eh, I'll adjust it more precisely after I turn it on" the thing still ran perfectly. Eventually dialed up the speed just a smidge and tweaked the sensitivity for kicks; smooth response to adjustments, no surging at all, will take any load. My hz fluctuations went from +/-2hz when running "perfectly" to +/-0.5hz. My voltage stays within a single-volt range.
Wish I had replaced the carb earlier, but I didn't waste much money that wouldn't have gone toward thoughtful preventative maintenance anyway (spark plug, oil, new springs, some high-energy petroleum distillates, fuel pump, fuel filter: all of these things either strictly needed replacing or were worth getting anyway before I drove off to Nowheresville USA). Mostly just time and frustration, which I've got plenty of.
Notes, in no particular order:
  • To replace the main governor spring, I backed the speed adjustment screw all the way out (counter clockwise) and put the sensitivity adjustment screw all the way in (clockwise). This collapsed the spring very close to its completely relaxed position and allowed me to install the new spring without stretching it very much. I then dialed both screws back to something like their original position before I started the genny again.
  • On earlier repairs (fuel pump, control board) I went out of my way to clean the genset and replace bad wire terminals. This was helpful AND taught me more about what parts lived where. I also learned not to trust PO's wiring (the bad aftermarket fuel pump was not only bad, but was miswired; my Onan guys caught this right away, after which I snagged a wiring diagram and puzzled out the correct configuration).
  • If there was a way to clean that KY Spec H carburetor, I tried it. I started out light, with Seafoam (many guys swear up and down that Seafoam is only for fuel stabilization and will not clear out gunk; I can't disagree), then with Berrymans B12, then with Birkebile 2+2 on a disassembled carb, then more Berrymans and Seafoam put through the running carb, then to a small engine shop's ultrasonic bath. The performance improved, but it never got close to what I'm seeing with the brand new carb. It's possible that these interventions will work if your carb is gunked from a season of fuel varnish, but I was staring down years of POs not using the generator at all.
  • The control board was not fried when I bought it; I think I fried it when I was starting it over and over (with bad wiring!) to feed gas through the carb. If I had another chance, I'd replace the carb immediately; I think the control board would still have fried from the wiring issue, but maybe not. My symptoms for the fried control board were that the generator wouldn't even engage the starting solenoid, not even a click. The Onan guys diagnosed it, and when I saw what the board looked like, it was very obviously melted.
  • The original starter solenoid, God bless 'er, is still perfect.
  • I'll be stabilizing all the fuel that goes through the rig's main tank (which feeds the genny). Cheap insurance.
  • It runs more quietly with the new carb, in addition to more smoothly. Adjustments to the speed and sensitivity also no longer cause wild reactions in engine speed and surging. This could be from the new springs, but I'm pretty sure it's the fact that the carb is healthy now.
  • Armed with the service manual, a wiring diagram, the right tools, and a clean workspace, I didn't find any of the work I performed to be terribly difficult. My genset stayed mounted under the rig the whole time. The most fiddly part was replacing the main governor spring (it's pretty far back in there); the second most annoying thing was the struggle of manhandling the carburetor, the gaskets, the choke and throttle linkages, and the air filter housing all at the same time during carburetor removal and reinstall.
Thanks for the tips! Education is the most expensive thing in the world, but I still feel like I got a pretty cheap primer on small engine repair after it was all said and done. If you're in the same position reading this (old, poorly maintained Onan generator that is surging under many conditions), STRONGLY consider putting a new carburetor in it as your FIRST intervention. I'll hang around the forum to yell that at newbies [emoticon]
gmctoyman
Lake Livingston, Texas
Posted: 07/15/18 11:49am Link  |  Quote  |  Print  |  Notify Moderator
Your source for the carb ?
Dave W. AKA "Toyman"
KE5GOH - On 146.52
RV's ? What RV's ???
Apache Pop-up
Classic GMC Motorhome
07 Leisure Travel Sprinter
Do Boats Count ?
Straylight
The Road
Posted: 07/16/18 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
I got my carb straight from my Onan dudes. It was $270ish after the 10% Power Club discount, and they had it in stock on the shelf.
Generator Jim
Conway, SC
Posted: 07/24/18 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
One thing for the future troubleshooting. The paper air filter can become oil soaked because the crankcase breather tube dumps into its intake airstream. If so, it will act like the choke is on and cause over fueling problems.
Jim & Jane Latour
08 Chevy 3500HD, crew cab, dually, Duramax/Allison
Crossroads Cruiser CR305SK14, Onan 3.6KY
Retired AF CMS (E9) Power Generation and Onan RV genset Level III tech
Grand Strand Sams
Blog.rv.net
pryoclastic
O-o-o-o-klahoma
Posted: 07/25/18 08:44am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for posting! This is actually a really good tip. I noticed this was the case on our air filter when I first started going through the generator systems after we got our coach.
Over fueling could also explain why the plugs smelled like gas.
Confirm / deny?
(btw .. username checks out)
Old_Man
Somewhere, CA
Posted: 11/20/18 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
Best thing you can do with an Onan is take it to Burning Man and burn it. Honda 1000 is all we'll need. Onans are obnoxiously loud and they stink the entire area.
Since I do not spend time in the cold I don't worry about Onans. I should probably sell it to someone...just taking up space back at the Howls, maybe I'll sell it cheap to some people who need it, or just give it to them. Ask them to pay it forward if they get a chance.
jplante4
Cape Cod
Posted: 11/21/18 06:17am Link  |  Quote  |  Print  |  Notify Moderator
Old_Man wrote:
All this is all the more reason I'll ditch the Onan and replace it with a Honda. Onans are stinky and noisy.
Not helpful.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
