RV.Net Open Roads Forum: Tech Issues: NorCold refrigerator
 > NorCold refrigerator
ceasare
staten island
Posted: 07/12/18 09:51am Link  |  Quote  |  Print  |  Notify Moderator
On the eastern shore of Virginia for a month. No having problems. Everything checks out unit running on gas, idiot lights are on. The refrigerator
Is still not getting cold. Even put in one of those little fans. No help. Any Ideas? It’s a 2016 Norcold.
midnightsadie
ohio
Posted: 07/12/18 10:02am Link  |  Quote  |  Print  |  Notify Moderator
whens last time burner was cleane?? how hot is it outside? is the sun facing the frig? these units don,t work very well in hi heat.
enblethen
Moses Lake, WA
Posted: 07/12/18 11:05am Link  |  Quote  |  Print  |  Notify Moderator
Any type of discoloration in the outside access?
I agree as to when was last time stack was cleaned? When was burner cleaned?
Norcold model number?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
sayoung
Tx
Posted: 07/12/18 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
Look around the shield where the burner is as the boiler most common leak area. If there is any greenish yellow stain its toast.
doxiemom11
Arizona
Posted: 07/12/18 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
Are the external fans working? Our stopped and we couldn't keep the frig cold. Had morning sun and it was hot. We didn't have awning out because of wind. Hubby installed computer fan to blow up in outside compartment, we pulled our awning for shade and frig is now running at 34 degrees. Made about a 10 degree difference. Check fans to see if working.
Old-Biscuit
Verde Valley
Just how long has fridge been ON?
Is RV level?
What does flame look like.....Strong steady BLUE and just reaching up inside of flue opening ---centered?
Does it run on AC?
What model of Norcold?
bgum
South Louisiana
Posted: 07/12/18 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Does it have thermistor and if so is it at very top of fin?
midnightsadie
ohio
Posted: 07/12/18 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
HEY OLD biscuit got a question? I all ways though the fan was suppose to be at the top,pulling air from the bottom.
Old-Biscuit
Verde Valley
Posted: 07/12/18 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
Norcold OEM fans originally were mid position center line jus above absorber tubes....pull air in lower vent up thru absorber tubes then push air up across condenser fins and then out upper vent
Now Norcold is installing them up higher so they are accessible w/o having to pull fridge
Fans down low near lower vent try to push air which is less 'directed' then by pulling air UP
Although anything to enhance draft is GOOD
ceasare
staten island
Posted: 07/13/18 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Yes to all check everything moved the transistor to the top of the fins and still nothing. But the freezer does seem to be working
