RV.Net Open Roads Forum: Travel Trailers: Low Shore Voltage
 > Low Shore Voltage
Page of 6
PApopup
Glen Rock, PA, USA
Posted: 07/12/18 10:21am Link  |  Quote  |  Print  |  Notify Moderator
Last week we ran into an issue where the campground shore power for our site was only coming in at 104 volts(30 amps). We have a Progressive surge protector and it would not let the power flow. Reported it as a Low Voltage. The campground was full so we ended going somewhere else at a lot more money but we enjoyed the weekend.
The campground staff was like it ran for the other folks fine. Indicating we would be OK to run without the surge protection. I was always under the impression that low power was just as bad as too much and not wanting to take a risk with the A/C and other components. The Progressive protector being our guide.
So, were we right to leave to avoid this power issue?
Bob, Kim, Gabby, & Matt">
2011 Flafstadff V-Lite 30WTBS ">
2010 Chevrolet Silverado 2500 LT Crew Cab 4X4 ">
enblethen
Moses Lake, WA
Posted: 07/12/18 10:22am Link  |  Quote  |  Print  |  Notify Moderator
Yes, low voltage can damage electrical equipment.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
SoundGuy
S Ontario
Posted: 07/12/18 10:35am Link  |  Quote  |  Print  |  Notify Moderator
Absolutely. Just because others are ignorant of the facts it doesn't change those facts - excessively low voltage is damaging but the effects are cumulative and don't necessarily show up right away. Those many who did plug into excessively low voltage may not have noticed any problem this time, nor next, nor the next after that, but do it enough times and they will be replacing parts, most notably the A/C. [emoticon]
Bishop, California
Posted: 07/12/18 10:41am Link  |  Quote  |  Print  |  Notify Moderator
You paid for a service that was not acceptable or safe for your RV. Ask for your money back. World's worse reason for doing or not doing anything..."like it ran for the other folks fine"
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
Lynnmor
Red Lion
Posted: 07/12/18 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Just think, used trailers are recommended on here quite often. If you buy used, be sure you get a price that will be low enough if the air conditioner was abused.
With the electric suppliers having problems producing enough power, and campgrounds having wiring that can't deliver enough voltage, I find that an autoformer is becoming a necessity.
valhalla360
No paticular place.
Posted: 07/12/18 11:16am Link  |  Quote  |  Print  |  Notify Moderator
You were correct to question the issue. Low voltage is worse than high voltage. I see you have 3 options (in my order of preference):
- Hook up an voltage booster (still might drop so far the voltage to the unit is low) often called an autoformer.
- Break out the generator (let them provide the contracted voltage if they don't like it).
- Pack up and demand a refund as they didn't provide the power you contracted for.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
pianotuna
Regina, SK, Canada
Posted: 07/12/18 11:23am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
If you have a way to travel to Mexico pick up a Sola Basic 4000 VA autoformer. It has three levels of boost (110, 100, 90), and one level of buck (135).
If you are not planning a trip--then perhaps you know someone who would pick one up for you.
I've used mine on 97 volts--it raised up the voltage to 109 inside the RV.
Regards, Don
time2roll
Posted: 07/12/18 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Would you knowingly run your vehicle on bad fuel so it overheats?
Yeh I didn't think so.
Another option is a voltage booster such as Hughes Autoformer.
675w Solar pictures back up
2oldman
Salton Sea
Posted: 07/12/18 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
PApopup wrote:
The campground staff was like it ran for the other folks fine. Indicating we would be OK to run without the surge protection.So, were we right to leave to avoid this power issue?
Yes you were.
Once again, CG staff dismissing an electrical problem for what it really is, and somehow 'blaming' your surge protector. Amazing, and typical. Caveat emptor in RV parks.
SoundGuy
S Ontario
Posted: 07/12/18 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
No where in the OP's post does he claim campground staff "blamed" his surge protector (in reality an EMS w/surge protection) but merely suggested he remove it and run directly from the power post. In reality, that's all they could have recommended as it's not like they can suddenly throw a magic switch and increase voltage back to where it should be. [emoticon] The OP instead made the only other choice available to him at the time - move to a different campground. If neither one of these solutions is acceptable then the OP has only one other alternative - invest in a voltage regulator such as a Hughes Autoformer that will boost low campground voltage so it is acceptable.
Page of 6
 > Low Shore Voltage
