RV.Net Open Roads Forum: Fifth-Wheels: synergy tires
 > synergy tires
kennethwooster
Perryton Tx USA
Posted: 07/28/18 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
Just wondering if anybody has used the Synergy tires. Especially on 5th wheel trailer. I need to replace all four a Cameo. Looking for opinions. were in a oil farming area and dealer says he's been selling this tire for trailers. He says he's had no problem. Its a 14 ply and looks like a rib.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
donn0128
Pronounced Ore-gun
Posted: 07/28/18 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
Made where?
cmeade
Kelseyville CA
Posted: 07/28/18 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
I just bought 4 Sailun G rated 14 ply tires dot date code is Jan 2018 from simpletire.com for our 14k fiver. Got tires in about five days. For the price seemed like a good deal and others posted good reviews. Glad the Trailer max tires are off the fiver. BTW less than $600 for four 235/80R16.
kennethwooster
Perryton Tx USA
Posted: 07/28/18 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Tires are manufactured ion Japan.
kennethwooster
Perryton Tx USA
Posted: 07/29/18 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
I’ve done quite a bit of research and cannot find any bad comments Guess I’ll give them a try.
buc1980
houston tx
Posted: 07/31/18 09:02am Link  |  Quote  |  Print  |  Notify Moderator
I can't find the tire load range or other specification.
2017 Ford F350 DRW,2005 Kountry Star 35ft,14750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.
laknox
Arizona
Posted: 07/31/18 09:21am Link  |  Quote  |  Print  |  Notify Moderator
Personally, I'd much rather go with a tire brand that's more well-known and has a track record. The Sailun seems to be an excellent choice, though you need to be sure your rims will handle the 110 psi for a G tire. Likely your FW is placarded for ST E tires, so may only have 80 psi rims.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 63 Year Member
CALandLIN
SC
Posted: 07/31/18 10:59pm Link  |  Quote  |  Print  |  Notify Moderator
A very popular ST tire size and built by just about all of the ST tire builders. Probably just right for your axles.
Click Here!
RAS43
Littleton,CO
Posted: 08/01/18 07:30am Link  |  Quote  |  Print  |  Notify Moderator
Click Here!
62lb 5 rib tire. Looks pretty stout.
GlenO
Terry, MS
Posted: 01/14/22 11:43am Link  |  Quote  |  Print  |  Notify Moderator
How has your experience been with the Synergy RV tires? I am looking at a set to replace some coming up on five years age. Thanks,
 > synergy tires
