RV.Net Open Roads Forum: Beginning RVing: Drinking water/filtration
 > Drinking water/filtration
jmoran
California
Posted: 09/30/18 11:03am Link  |  Quote  |  Print  |  Notify Moderator
GordonThree wrote:
What's wrong with tap water? Survived a long time on the stuff myself.
You may want to read this
***Link Removed***
Wherever I happen to park
Posted: 09/30/18 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
What is wrong with tap water short version.
Tap water is not 100% water. there are minerals and other impurities. may even be bacteria in the water.. NOW..
I know we all grew up (i hope) on tap water but you get used to the specific water where you live.. Takes me about a week to adjust to a new water supply if it's different enough (Story follows)
And some of the "Tap" water I've seen.. is not fit to drink.. High mineral content. High sulfur content or other stuff I'd rather not drink.
City near where I summer has people dying from lead in the tap water.
yup Dying.
so that's what's wrong with tap water.
Now.. What's wrong with Bottled water... A lot of it is tap water.
There are other sources like Lake Michigan.. Which happens to be a political hot potato but I'm only commenting on it as a source. Good water far as I know. Many other sources a well.
PLUS the chemicals that the bottle gifts you with. Plus cost
(Waffle House sells 16.9oz bottles for $1.69 chilled. Folks that is 12.80/gallon and you thought GASOLINE was expensive [emoticon].
The story
Last summer I tanked up every 2 weeks need it or not (and it was always not) Till Halloween Went from Oct 30 to Thanksgiving morning before I ran out of water (80 gallon tank) all the water came from the dame 12 well system (the park has 12 wells) when I was in another park I used, as I am now, water from THAT park.
Thanksgiving noon I tanked up. for the first time that season at a DIFFERENT system.. same 80 gallons lasted a week.. WHY.. Well I had to flush more often.
Home is where I park it.
harley-dave
ummm, where are we again..
Posted: 10/01/18 08:20am Link  |  Quote  |  Print  |  Notify Moderator
We use a Camco external filter and an under sink Everpure H-54 Here which feeds a separate faucet by the sink and the ice maker.
Dave
2005 Winnebago-Itasca Sundancer 31C
2010 Harley-Davidson Soft tail Deluxe
2014 Harley-Davidson Street Glide Special
1999 Chevrolet Tracker 4X4
SKP # 121272
Old_Man
Somewhere, CA
Posted: 10/08/18 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
We will be using two Camco (or equivalent) inline filters, and the "South of the border" system from the RV Filter store, in addition to under-sink ceramic and charcoal filters, PLUS, chemical purification. Given we'll be spending a lot of time in SW Arizona in the winter (Coyote Howls, BABY!!!) and we'll need all the help we can get.
matross
Torrance, California
Posted: 02/07/19 01:00am Link  |  Quote  |  Print  |  Notify Moderator
You might want to discover ***Link Removed***Go Berkey kit. It's a portable water filter.
ependydad
Here and there
Posted: 02/07/19 09:52am Link  |  Quote  |  Print  |  Notify Moderator
I see a moderator cleaned up the Berkey link. When we went fulltiming, we started buying 10-12 gallons of water each week. Usually in 2 1/2 gallon jugs we kept in the fridge and then another case of water for "grab and go" water as we went out.
With a Berkey Water Filter and a set of resuable bottles, we haven't bought water in about 2 years. We bought a 2 gallon jug from Amazon and refill that directly from the Berkey. We keep the 2 gallon jug in the fridge so that we have fresh cold water always on hand.
http://learntorv.com/berkey/
We added a Berkey showerhead filter, as well. My wife says her hair is softer and it protects the colors she puts in.
2017 Spartan 1245 by Prime Time
2012 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: B&W Turnover Ball + Companion
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
Posted: 02/07/19 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
Pure water (I am talking lab quality pure) Is not good for you either. By the way we all know water conducts electricity right.. WRONG pure water and again I'm talking lab quality. does not.. (I know I've used it in a lab and it was very important it not conduct).
You are correct about mineral and bacteria in well or even city water. And it varies from area to area or even house to house on the same street in some cases.. Now normally you stick close to home and you won't have any issues. but if you travel great distance....
I spent all summer tanking up (RV has a 80 Gallon tank) every 2 weeks I was doing the 2 weeks here two there 2 here bit and at one CG I'd hook up and tank up upon arrival. tank up again before I left and use JUST water from that CG save for laundry (Which (I did at the other CG) Finally I packed up and went south for the winter. 70 gallons lasted from Halloween EVE (When (I tanked up) TO Thanksgiving Morning that's when I hit empty.
Tanked up again and This time at my winter quarters. and went through 80 gallons in 7 days.. WHY. .Additional flushing.. Yup I got hit with the "Different water" effect.. Well I tanked up again 2 more times at one week intervals but the tank was NOT empty. then it was 2 weeks/1 week for the winter. I'm a bit more water efficient this year. every 3 weeks in the winter (Will go back to 2 weeks come summer due to logistics of it).
And I've been in parks where frankly I could not drink the water (Very bad) without filtration.
Now why is pure water not good? Some of the minerals are essent9ial. if you know what they are you can take supplements but.. I'm not sure what they are.
IF you are SERIOUSLY bothered a Reverse Osmosis filter gives near lab quality pure. However there is a trade off with them I don't care for.
I use a simple granulated charcoal filter (home made)
Big pipe (Mine is 3" I suggest 2) with reducers on each end to a garden hose (male and female) one end can be unscrewed to re-fill.
Stainless steel grid (Drain cover) each end.
Filter floos. Activated charcoal (the basic kind not the fancy stuff with algaecide) more floss and close it up. I use a full PINT of charcoal (or more) and change it from time to time.
THen I PUR what I drink as well.
CincyGus
Cincinnati
Posted: 02/10/19 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
I buy the 2.5 gallon water jugs for drinking and cooking and we use an inline camco filter for the water for showers and dish washing.
2015 GMC 2500 Denali Crewcab 4x4
2019 Forest River Wolfpack 23pack15
Hope your travels are safe and the friendships made camping are lasting.
