RV.Net Open Roads Forum: Tech Issues: smaller roof AC
 > smaller roof AC
htwheelz67
orange county
Posted: 05/14/19 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
look at the dometic B59530 hi efficiency AC I bought two for my toyhauler it only pulls 11 amps and can run off a 15A breaker, I think you can run two off a 4k gen.
3 tons
NV.
Posted: 05/14/19 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
philh wrote:
ajriding wrote:
trying to get one to run off the gen is.
Soft start RTFW
Uh oh, here comes another acronym...
ajriding
st clair
Posted: 08/19/19 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
As for the Coleman Mach 8 9200 btu roof AC, yes it does get a small camper cold.
I just installed one on a TC.
92-94 degrees, full sun, 900 feet elevation, condenser side facing the sun, and plenty cool inside.
Again today while working in camper I ran AC. Though it was in the 80's this time, I only had to set the thermostat halfway (it runs on a dial, not a specific number) to keep it cool and on Low fan speed.
It is quiet (for an AC) inside on low, High fan speed is more noisey, not what you want to sleep to.
It does get loud outside only because there is a smaller fan running over the condenser coils and there is wind noise from the air moving past the grill on the shroud too. This noise is outside, who cares, and not inside.
So far I am happy.
I have yet to pull out the 2200 watt generator, but I imagine it is more than enough to run this
map40
Posted: 08/20/19 06:08am Link  |  Quote  |  Print  |  Notify Moderator
Stop the madness!!!!!
In my fleet I have all Atwood Aircommand command. I have 2 Ryobi 2200 generators and they individually run those airs with no problem. The ACs perform better than any other brand...
Alfa SeeYa, 2015 Jayco XL31, 2015 Itasca XL31, 2012 CA 25, 2008 CA 28. RV with most millage: 312K miles on a V10
Life rocks when your home rolls
 > smaller roof AC
