RV.Net Open Roads Forum: Tech Issues: Replacement compartment latch / rekey? Items stolen?
 > Replacement compartment latch / rekey? Items stolen?
SJ-Chris
San Jose, Ca
Posted: 09/13/18 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Hi All,
All of my external storage compartments have locks that are opened/locked with one key EXCEPT for one compartment (ugh). This forces me to have two different keys. I would like to convert the one odd-ball latch to one that will work with the key that is used on all the others.
Does anyone know if a locksmith can convert the one odd-ball latch to work with the same key as all the others? Or is there a micro-stamp part# somewhere on these latches that would tell me which replacement latch I could order?
Let me know. Thanks!
Not that it should matter on this issue, but this is for a 2008 Four Winds 31p Chateau Class C RV.
I did google and find out that a huge percentage of these RV compartment latches are opened by the SAME key...meaning that if people wanted to open up your compartments there's a decent chance they can do it with one of their keys. How many of you have gone and changed ALL your external compartments to a different/unique key? I found this place online: ch751.com
Have any of you had stuff stolen from your external compartments (...likely because so many others have your same key??)? Just curious.
Thanks!
-Chris
IAMICHABOD
Sunny So Cal 90713
Posted: 09/13/18 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
I have replaced all of mine just like those on my 2006 Tioga with These ,they can all be keyed alike so I only have one key for everything. Just pick the size and how many you want.
I also like that they have a cover on the key slot that moves when you insert the key,thus keeping all grime out.
* This post was edited 09/13/18 04:39pm by IAMICHABOD *
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
donn0128
Pronounced Ore-gun
Posted: 09/13/18 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
Instead of using the genearic 751 key why not buy some of the barrel locks and replace everything. Barrel locks are readily available on places like Amazon and large RV parts stores. Probably wont cost you any more than rekeying a bunch of locks.
fj12ryder
Platte City, MO
Posted: 09/13/18 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
The only time we ever lock our compartments is when the trailer is in storage. Never had anything stolen, or messed with. Spend your money on more important stuff, like beer and BBQ. [emoticon]
Howard and Peggy
"Don't Panic"
mike-s
Michigan
Posted: 09/13/18 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
Which probably means you need THREE keys. One for the door, one for that hatch, and one for the other hatches.
IAMICHABOD is right - if you have the most common door lock, you can upgrade all the hatches to use the same key. So, only ONE key for everything, and way more secure than the CH751 locks on 99% of RV hatches.
Bonus: you get a key with each lock cylinder you order, so you'll have lots of spares!
Con: there's a master key which will still open them, and although they're only supposed to be sold to dealers and locksmiths, I wouldn't count on that.
agesilaus
North Florida
Posted: 09/13/18 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
I'd look at these Barrel lock set
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
bpounds
Sophmore Brain...
Posted: 09/13/18 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
I lock mine while driving to prevent them from possibly vibrating open. Had that happen to a propane compartment door. Unfortunately those are not allowed to be locked, but I was able to tweak the door casing a little so that it won't happen again. But, just like you, once we are deployed on a site, they hardly ever get locked while we are there.
As others said, those lock are available everywhere, and easy to change out.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Almot
out there
x2.
Order 4 (or how many y need), they will all come with same keys. Moreover, there is a good chance that somebody on the camp could open your hatches if he has barrel locks too - the same is true for flat keys as well. At least, barrels are a little less common than flat keys.
IMPORTANT: measure the depth of the threaded part of lock before ordering, they come in different sizes.
jcsb
Sharonville, OH
Posted: 09/13/18 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
Have the standard 751 key. Easy to replace if needed. Never have had any thefts.
If we did lock them and someone wants to get in, a decent screwdriver will pop the door easily and that damage will be far more costly than the contents.
Jim Hunter
fj12ryder
Platte City, MO
Posted: 09/13/18 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
If a person wants into your storage compartment the best lock money can buy will not even slow them down. Any storage compartment on a trailer can be easily opened with a medium to large screwdriver, a pry bar isn't even needed. Just take a look at the surrounding aluminum framework, flimsy and easily damaged.
Those expensive locks might even cause more damage since a thief may figure there's actually something worth stealing behind those fancy locks.
