RV.Net Open Roads Forum: Class C Motorhomes: Filling inside rear tires
 > Filling inside rear tires
BillHoughton
West of the Mississippi
Posted: 09/14/18 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, all.
I talked with the Sprinter service writer at the Mercedes dealership, where we get this RV serviced, and he said Mercedes offers some plastic extensions that he does NOT recommend.
I wound up talking with the truck tire mechanic at a local place, and he said:
(a) braided flexible extensions always fail.
(b) rigid extensions always fail, though not as fast.
(c) long valve stems would be the solution, except that, because of the way Mercedes makes wheels, none of the long valve stems they can get will fit.
In his opinion, the only workable way to go is with short valve stems - which means airing up the inner tires from the inside (there is clearance, but it wont be fun), or learning how to reach through a small opening with a tire pressure gauge and air chuck. I think a tire pressure monitoring system is in my future!
chuckbear
Posted: 09/15/18 10:18am Link  |  Quote  |  Print  |  Notify Moderator
I installed valve extensions two years ago. I also added rubber insert valve extension stabilizers to each extension. They fit in the hole n the rim. No movement or abrasion and no loss of air whatsoever. Easy to top off after normal loss every 12 months or so and TP sensors all work fine. Chuck
BruceMc
Oregon - Willamette Valley
Posted: 09/19/18 11:35am Link  |  Quote  |  Print  |  Notify Moderator
I faced this same issue on the Ford, and now that I have Pacific Dualies wheel liners on my Chevy, it's a similar situation.
Here's what I've done:
First, the kit:
compressor, double foot straight gauge, valve extender, 11/32nds hose
I've installed these short extensions on both motorhomes now, neither has been an issue over the years. I tightened them to the original valve stem with tiny adjustable slip-joint pliers when I installed them, and to date, never had a leak:
For the inner dual: peering through that "handhole" that some Ford "engineer" should have had their head examined....:
Simply use the 11/32nds hose to reach in and remove the cap:
Result:
Reach in with your double-foot gauge to check the pressure:
If you do need to add air, use one of those dastardly extensions attached to the inner dual shrader. The female end of the hose is fixed - it will not rotate independent of the hose. Thus, it can be installed by twisting the hose:
Attach your compressor:
It helps to have a screw on fitting, where the push-on style is difficult when holding the push-on to the hose, and turning on the compressor. two people (or three hands....) would be helpful. One of the push-on type with the hold clip would help, or having a large compressor that has a holding tank.
This setup would work on the sprinter as well.
'16 Forest River Sunseeker 2250SLEC Chevrolet 6.0L
Previously:
'00 Four Winds 26Q Class C (Ford E350 V10)
'96 Kit Sportsmaster 212f Fifth Wheel/'93 GMC Sierra K2500
'91 SunLite poptop truck camper
and the first: a Wildernest flip-top canopy.
vjswhippet
Cleveland, MO
Posted: 09/19/18 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
My Sprinter Vista Mini by Gulfstream has a bracket to hold the inside and outside valve stem. It's a 2008 so it must be working or they whould have changed it out ? I've not had any problems in 4 trips so far.
Vickie Smith
Kansas City area
2008 Gulf Stream Vista Cruiser Mini 4230
Hank85713
Tucson, Az
Posted: 09/19/18 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
We have the alcoa wheels so they have the steel wheels on the inside. I put 4 inch extensions on the inner stems with a small dab of locktite to keep them on. have worked well in the 5 years we have had the setup. Only problem is that tps will NOT work with the extenders. Bought some of the long stems from the tire guy in kalif, just have not been able to get over to the tire shop to get installed so I can use the valve stem tps I bought. if using the locktite get the red 222 which is a low strength one or 242 which is medium. Just dont get carried away with it so it does not get into the valve core.
Dakzuki
Carnation, Wa, USA
Posted: 09/20/18 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
The OE extenders are bad news on the Sprinter. I had a stem failure due to them.
These folks will set you up with rigid long valve stems that have the inner stem supported. Call them and Kelly will set you up with what you need. She really knows her stuff. Their post sales support is exemplary too.
2011 Itasca Navion 24J
2000 Chev Tracker Toad
CharlesinGA
South of Atlanta, Georgia
Posted: 09/22/18 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
I too have a 2007 Winnebago View on a 2006 Dodge/Mercedes Sprinter chassis, same as the OP.
What I suggest is..........
1) remove the simulators if you have them, and store them away. If you want, like I did, buy a couple of Mercedes plastic hub caps for the front wheels.
2) install Alligator air thru the caps.... caps. Well made, in Germany, of brass.
3) buy a tire pressure gauge like the one Harvey shows, at least one with the same straight/back angle chuck and long stem, there are a number of them on the market.
4) buy the long Milton straight/back angle servicing chuck, and I went so far as to install smooth "nuts" in the chuck rather than the grooved ones designed to lock onto the grooved caps or threaded stems.
Here is my post from a thread back in Feburary.
Harvey51 wrote:
When we bought our 4 year old MH, I didn't buy special stems. The used Ford had plastic extenders on the valve stems and I managed quite nicely with pressure gauges like this and a similar inflation head for my compressor.
[image]P
The straight on end is necessary for the inner wheel and the backward angle one for the outer s which must have the valve stem long enough to be close to the rim opening. I have had a service station add air twice and they both had the appropriate inflation tool. I rarely use my portable air pump but it is a comfort to have for sure,
I never had trouble that a plastic extender but a metal one I tried failed to close after I checked the pressure at a rest stop. I got the darn thing off quickly enough to limp to a service station.
With the first set of new tires I got Costco to install longer valve stems (rubber) and have never needed extenders since. I also decided to put regular valve caps on to keep things clean, using a short length of plastic tubing with a wood dowel holder to take off and put them back on. It takes about 5 minutes to check all the tire pressures. Would be a little faster if I marked the spot on the rim where the stems are located. The Costco installer thoughtfully installed the wheels so both inner and outer valves are in the same big rim opening.
The gauges shown by Harvey are the type I recommend. It makes checking pressures with standard stems very easy.
For balance purposes, the wheels should have been mounted with the stems 180 degrees apart, directly opposite each other.
I tried the Borg stems on my Sprinter and quickly gave up and had the tire shop break down the wheels and remove them. We reinstalled standard rubber/brass 80 psi truck stems. I had jacked it up and home and pulled the wheels, part of the problem was that I quickly discovered that it was very difficult to install the wheels without damaging the stems, the stems also did not fit properly even though they were supposed to be bent properly and also that the long stem on the inner wheel makes it impossible to interchange it to any other position without breaking it down and swapping the stems, and this requires more seals as you damage the seals getting it apart.
The sprinter stems tend to point somewhat inward and you have to wiggle the gauge or service chuck around to flex the stem outward somewhat, but when you push hard, they seat/seal easily. This inward turn is part of what makes the Borg stems so difficult to install on a Sprinter, They need three or four slight bends in them to work, and you are still stuck with the difficulty of removing or installing the wheels without damage to the stems.
To Borg's credit, they promptly refunded me all of my money and I was happy. Possibly on other vehicles they fit better, but the problem of non-interchangeability of rims with the long stems and the difficulty of mounting wheels on the vehicle without damaging the stems is still present.
I do not run wheel simulators. I removed them as soon as I got the vehicle home when I bought it. I use a slime gauge similar to the one Harvey shows, plus a Milton 12 inch long straight/reverse angle air chuck https://www.amazon.com/gp/product/B004QI........=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1 Plus German made brass Alligator V2B service thru the cap, valve stem caps. Keeps dirt out of the stem, but eliminates the need to remove caps to service or check pressure. https://www.amazon.com/Alligator-V2B-Inf........4646&sr=1-1&keywords=alliGATOR+tire+caps
The Milton chuck has grooves inside the ends to allow it to "lock on" to the thread on a valve stem or the machined locking grooves (which are not threads) on the Alligator caps. This makes the chuck frustrating to use, so I replaced the seal retainer/end nuts on the Milton with smooth, ungrooved ones, https://www.miltonindustries.com/dual-head-chuck-nut.html
Charles
BillHoughton
Posted: 01/17/19 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
Coming back to visit this one with an update. After some roaming around trying to get answers, I was referred to Borg Equipment (shows up on the interweb as http://yourtireshopsupply.com/), where I was able to get long valve stems bent specifically to fit my year of Sprinter. I had them installed at a local tire shop, and they look like the solution. They are sold with rubber stabilizer fillers for the vent hole in the outer rim through which they exit, and they're right simple to reach. It was pointed out to me that they'll make rotating the tires more expensive, but I rarely rotate tires anyway, so I'm not worried. I got great service from Kelli there. We haven't taken the rig on the road yet, but I'm impressed so far.
GKAbbott
On the road
Posted: 01/17/19 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
My Coachman came with the same or similar setup. My only problem with this setup is that I cannot access the stem with the hubcap/simulator in place. On my
Rear simulators there is no relief for the stem. Yet there is a relief on the fronts. I guess I'll have to cut the reliefs myself.
Expyinflight
Mesa, Arizona
Posted: 01/18/19 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
They are....the solution. You will be very happy. Money well spent.
2017 Winnebago Spirit 25b
