RV.Net Open Roads Forum: General RVing Issues: Tire Pressure Monitoring Systems TPMS
 > Tire Pressure Monitoring Systems TPMS
garmp
St Louis, MO
Posted: 09/15/18 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
This subject has probably been beaten to death, but I could find very little on it.
What's the best Tire Pressure Monitoring Systems, TPMS, for the buck in your opinion? Sorta leaning toward either the EEZ Tire Pressure System or the TST 507, both pass through.
How about installation? We were just at a Phoenix Cruiser Rally and the people I talked to that had them had them all mounted to the wheel covers. Some welded, some riveted on. Either way this does not sound like easy self installation.
Pass or flow through vs. standard? I'm leaning toward the pass through. I'm getting older at a rapid pace and the old hands just don't work like they use to. Simple is better!
Any and all info is greatly appreciated.
Thanks
Our Phoenix Cruiser 2100, "Bob", has turned us from campers into RVers and loving it!
Ltrip
Reno, NV
Posted: 09/15/18 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
I think this has been beaten to death. Try searching some more.
I have the TST and love it. Easy installation. The sending unit screws onto the valve stem. The monitor sits on your dash. Follow the instructions to sync the sender to the monitor....this is the hardest part. But TST support is excellent.
The system has saved me 3 or 4 times.
Don;t leave home without it!!
Cheers,
Larie Trippet Reno/Tahoe region
2018 Ford F250 Lariat Ultimate CC SB 4X4 diesel
2018 Arctic Fox 25Y
2014 BMW R1200GSA
Second Chance
Wherever...
Posted: 09/15/18 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
X2^^.
Rob
U.S. Army retired
2016 Grand Design Reflection 337RLS
MOR/ryde independent suspension, disc brakes, LR G tires
2020 Solitude 310GK-R on order (with MORryde IS)
PullRite OE 18K, Demco Glide Ride pin box
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
delwhjr
TX
Posted: 09/15/18 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
I have the TST and second the positive experience.
If you want the flow through make sure you have metal valve stems(TST recommedation) I took off the security ring on my caps and just screwed them on. Have many miles and no problems.
2019 F250 Crew 4x4 6.2
2019 Rockwood UltraLite 2608BSD
jplante4
Cape Cod
Posted: 09/15/18 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
I searched on tpms and got 24 pages. Beat to death? Uh Yup.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
delwhjr
TX
Posted: 09/15/18 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
Not true, it is only beat to death once it has been thoroughly discussed as beat to death! [emoticon]
BB_TX
McKinney, Texas
Posted: 09/15/18 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
TST 507 for years now. Sensors screw on valve stems like a valve cap. Mine are not the flow thru type. I add 2-3 lbs air each spring and good for the season. I remove them each fall to conserve battery life. And put them back on in the spring after adding air if necessary.
garyemunson
Reno, Nevada
Posted: 09/15/18 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
I've had the eez for 3 years now. The batteries are easy to replace (and cheap). I have the non-flo-thru sensors. One less place to leak. Does not require any reprogramming after battery replacement. It just goes back to working. I really think they are all good. Anyone have a bad experience with a particular brand?
ncrowley
Utah
Posted: 09/15/18 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
Tire Minder is our preference. We have had ours for over 5 years and thecustomer service has been excellent and it works.
Nancy
Newmar Northern Star
pawpaw47
Cypress, TX
Posted: 09/16/18 04:49am Link  |  Quote  |  Print  |  Notify Moderator
TST RV507 for us. We been using it for about 4 years now. Change the batteries annually and you wont have any issues at all. Oh, and you might consider using their repeater if your trailer is over 30 ft. long.
Good luck and happy camping!
2015 Starcraft Autumn Ridge 329BHU
2015 Starcraft AR-One 18QB
2014 GMC w/6.2L & max tow pkge.
