RV.Net Open Roads Forum: Tech Issues: Flaky Furnace Thermostat
 > Flaky Furnace Thermostat
Page of 5
BFL13
Victoria, BC
Posted: 11/09/19 09:27am Link  |  Quote  |  Print  |  Notify Moderator
According to Figure 6 here, the Tstat gets two blue wires (same as my Atwood's)
https://manuals.heartlandowners.org/manu........n/SF-20-25-30-35-42_Furnace_Suburban.pdf
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
CarnationSailor
Carnation,WA
Posted: 11/09/19 09:32am Link  |  Quote  |  Print  |  Notify Moderator
BFL13 wrote:
The Suburban gas furnace Installation manual should explain which wires to use with the thermostat. ( Any link to the manual on Google? We could check that out.)
Of the three wires you need two with this Tstat AFAIK, but which two? IMO you can find out by touching them together.
Yes, the Tstat is just a switch and has its own battery to power it, so it does not matter if the wire ends on W and R are 12v.
Do you mean to go without the air conditioner and heat pump now, and just have the furnace? (Where we camp on the Island here we never need air conditioning, but YMMV)
From the tstat manual, the only thing that makes sense is to connect the red (+12 vdc) to the white (Furnace) via the additional tstat. But this didn't work and you seem sure that it doesn't matter that the 2nd tstat is made for a 24 vac system. Maybe that means that the tstat that I bought from Lowe's is bad?
No, I don't intend to go without the air conditioner and heat pump. Everything works fine now EXCEPT the OEM tstat (which I have replaced to no avail) randomly jumps to its default setting of 72 degrees ONLY when using the furnace. That is quite uncomfortable when it does it in the middle of the night after we have set it to 66 and the bedroom (being the highest place in the 5th-wheel) gets up to around 75 or so.
My plan has been to move the furnace control from the OEM tstat to a new "heat only" tstat. My plan is not to replace the OEM tstat.
(All of this is documented earlier on in this thread.)
As long as the outside temps are above 40, we get by with the heat pump and fireplace, but the furnace is our only option when dry camping.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
BFL13
Victoria, BC
Posted: 11/09/19 09:50am Link  |  Quote  |  Print  |  Notify Moderator
Ok, I thought you disabled the OEM Tstat by removing the white wire and moving it over to the new Furnace only Tstat.
I don't have a clue about the heat pump side and all that. Doug has some ideas earlier in the thread--he does have a clue!
CarnationSailor
Carnation,WA
Posted: 11/09/19 10:09am Link  |  Quote  |  Print  |  Notify Moderator
Yes, Doug seems to be very knowledgeable. He did say that my problem can be difficult to troubleshoot. That is why I have abandoned trying to fix the problem and am trying to make this work around work.
Thanks for your time helping me.
DrewE
Vermont
Posted: 11/09/19 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Does it work if you manually connect the wires together (no thermostat involved)? If not, does it work to connect the white to the other (ground) wire? One pair of them should make the furnace run, and those are the two that get connected to the thermostat. Since it has a battery, ignore the 24VAC power connections entirely. If manually jumping the wires makes the furnace run but connecting them to the thermostat does not, then it would seem the thermostat is indeed bad or you're misunderstanding the connections to it--which admittedly is not at all hard to do with some thermostats as the conventions and instructions for wiring them seem to have been invented by insane Martians.
If no combination of wires makes the furnace run, then perhaps you accidentally shorted the wrong ones together at some point and blew the furnace fuse (there may well be a smallish value one on the furnace control board).
CarnationSailor
Carnation,WA
Posted: 11/09/19 10:28am Link  |  Quote  |  Print  |  Notify Moderator
The furnace still works when controlled via the OEM tstat so no blown fuse.
Although it seems logical to me that the only wires from the furnace to use are the red (+12 vdc) and the white ("Furnace"), I will test that by shorting them together. (I'm pretty sure if I involve the one labeled "-12 vdc", I'm going to end up send 12 volts to ground and blowing a fuse somewhere.)
Since we are leaving for Palm Springs in the morning, I'll postpone any further troubleshooting until we get there. (It's upper 80's there now so I can risk accidentally disabling both my furnace and my heat pump AFTER we get there!)
BFL13
Victoria, BC
Posted: 11/09/19 11:09am Link  |  Quote  |  Print  |  Notify Moderator
The two wires that go on the furnace-only Tstat are not pos and neg. It is one pos 12v wire that is cut with the Tstat inserted so that it switches that one wire.
The two blue wires heading from the power end of the furnace to the Tstat is like that. I am guessing your two blues go to some complicated connection place that has different colour wires coming out of it to that complicated OEM Tstat that runs all those things, so you can't tell which is each end of the "one" wire to use with the new furnace-only Tstat.
IMO put the OEM wires back where they were, and start over by grabbing the two blues closer to the furnace where you can tell which they are, cut them there, add more wire to each blue where you cut them going to the new Tstat location. That should get you furnace only.
Now the trick would be whether the OEM Tstat will still run the air and the heat pump properly, except now it won't go to furnace when its "gap" gets that way. It seems your OEM's brain isn't working right for how it switches between heat pump and furnace. That leaves you to pick the heat source, if the OEM Tstat still runs the heat pump ok.
I don't know where that brain is located. You replaced the OEM Tstat and nothing changed, so the broken brain must be elsewhere. Not a clue, but could be a control board in the mix that is not in the Tstat. Or as was suggested, there is bad wire connection to the OEM's brain that did not get fixed by replacing the OEM Tstat.
Some of those boards have wire connections that slide on to the edge of the board where there are contacts. Sometimes pulling them off the edge and cleaning the contacts and putting them back on is all it takes to get things going again.
CarnationSailor
Carnation,WA
Posted: 11/09/19 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
BFL13,
"It seems your OEM's brain isn't working right for how it switches between heat pump and furnace."
It works as specified. If I am in heat pump mode and increase the setting by 5 or more degrees above the current room temp, it automatically turns the furnace on to augment the heat pump. That is the only heat pump/furnace interaction that is supposed to happen.
I just put a meter on the OEM tsat. With the system OFF, I have 12 vdc on the red wire's connection point inside the tstat and 0 vdc on the white wire's connection point. (I am reasonably sure these wires come from/to the furnace.) Then when I switch to "Gas Heat" mode, the white (and red) wire's connection point has 12 vdc on it, and the furnace turns on. This is consistent with the tstat's manual which says that it "energizes" the furnace via the WF (White Furnace) wire.
So I seem to have a red wire and a white wire coming from the furnace that are "shorted" together by the tstat - much as your two blue wires are shorted together by a heat-only tstat. I still think the problem has to do with the tstat I bought from Lowe's. However, as you say, things could be much more complicated than this.
Tracing wires and/or replacing the wires between the furnace and the tstat is going to be a last resort option as my furnace is in a very inaccessible area.
BFL13
Victoria, BC
Posted: 11/09/19 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Deleted-- got that wrong about the single white wire being in two parts. So not a clue! Unfortunately post was quoted next, so ignore that in there too! [emoticon]
* This post was edited 11/10/19 05:42pm by BFL13 *
CarnationSailor
Carnation,WA
Posted: 11/09/19 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
BFL13 wrote:
Doug's link to the Tstat shows that on "Gas"- the WF (white) is energized.
Heat pump has white/black energized.
I take it that the Gas switch position connects the two parts of the white wire so that acts like connecting the two ends of the blue wires.
I assume the red wire is just to power the Tstat. When you go to the Heat pump position, that energizes both the gas and the HP so they do that "gap" routine.
Your mystery is why when on Gas only and you have set 66F, it sometimes sets itself to 72F, the default after a power interruption to the Tstat.
The Red wire power to the Tstat is not from the furnace as such (which should have its own 12v power supply that the Tstat switches), but it might come from the same connection the furnace gets its power from. Say the Tstat's connection is loose but the furnace's connection is tight.
Or not making contact inside one of those wire nuts mentioned?
Assumes the furnace keeps running after the Tstat jumps to 72 and now the problem is just that it gets too warm in the RV. Assumes the furnace will cycle off at 72.
You said the problem does not happen when in heat pump mode where both the HP and the furnace are energized and you get to where you are on furnace assist. Mystery why a loose red wire would not lose its contact sometimes then too.
Yes, however, heat pump mode does not energize both the heat pump and the furnace. It energizes only the heat pump except when the tstat is calling for a 5 or more degree increase.
Page of 5
