RV.Net Open Roads Forum: General RVing Issues: Colour of water hose
 > Colour of water hose
Page of 9
swimmer_spe
Sudbury, Ontario, Canada
Posted: 09/26/18 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
The water hose between the tap and the trailer, why are they white? Any issues with using a new garden hose instead?
romore
Okanagan valley British Columbia
Posted: 09/26/18 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
The white hose is specifically designed for potable water, a garden hose can contain impurities and leave a taste. Besides, you don't want to accidently use the one for rinsing the waste tanks.
mike-s
Michigan
Posted: 09/26/18 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
They're not all white. I have a blue one. But they're typically not the common green or black of garden hoses.
Garden hoses usually use plastics which add bad chemicals/flavors to the water, especially when they sit in the sun for a while with no flow.
Get a hose made for potable water, they really don't cost much more than garden hoses.
DutchmenSport
Over There
Posted: 09/26/18 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is yellow and green. Green for black water flushing, yellow for fresh water filling. When I first started using the yellow hoses, all 200 feet, I ran straight bleach through them. Then flushed them out and never had hose taste, unlike my brown one on the ground at home. I still drink from it though.
mobeewan
Hampton, Va
Posted: 09/26/18 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
As said typically white hoses are drinking water safe, however I did get a couple about 6 years ago from Lowe's that were blue and they were drinking water safe. They had a white liner on the inside that was made out of food grade material. They were a bit stiffer than the white Swan brand hoses, especially in cold weather. What ever you get, just make sure the label says it is drinking water safe or the lining is made from food grade material.
swimmer_spe
Posted: 09/26/18 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
OP here.
I don't ever plan on hooking up water and have it pressurizing my system. It is only to fill the tank and then put it away, out of the sun.
mike-s
Michigan
Posted: 09/26/18 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
swimmer_spe wrote:
OP here.
So, save $2 and take a risk of getting cancer or ???. If you don't care, why should anyone else?
MitchF150
Puyallup, WA
Posted: 09/26/18 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
I don't hook up to camp water either.. I fill up at home, but use a white potable water hose when I do it..
Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2003 Prowler Lynx 722F #5000 GVWR and weighs every bit of it! "> Happy Camping!
Old-Biscuit
Verde Valley
Posted: 09/26/18 11:39pm Link  |  Quote  |  Print  |  Notify Moderator
swimmer_spe wrote:
OP here.
That is a good plan.
I don't hookup to city water connection either
Use to but back in 2008 a $.50 fitting broke and flooded my 5th wheel while sleeping....$6000 repairs/costs
So it has been fresh water tank/pump ever since
BUT I still use a POTABLE water hose to fill tank with
valhalla360
No paticular place.
Posted: 09/27/18 01:08am Link  |  Quote  |  Print  |  Notify Moderator
It's cheap to buy the white hose, so why bother with the alternative.
That said, talk about cancer is hype or we would all be long dead. If I only had a green hose and needed to fill the tank I would do so with no worries.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Page of 9
