RV.Net Open Roads Forum: Travel Trailers: Propane tanks
Page of 6
marcsbigfoot20b27
Phx
Posted: 10/16/18 11:40am Link  |  Quote  |  Print  |  Notify Moderator
LScamper wrote:
TankCheck does a sound check and shows results on a monitor or a smart phone in percent or inches.
Have had a set for over a year. One was bad the other, the sensor came out of the body. They are very finicky. They did send a new one but it’s hit or miss to get them to work.
LVJJJ
NW WASHINGTON
Posted: 10/16/18 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
I loosen the hold down wing bolt, lift each tank. If real heavy, full, if light weight, empty. Done it for so long I can tell if half full , third full etc.
Tried the stickers, didn't work
1994 GMC Suburban K1500
2005 Trail Cruiser TC26QBC
1965 CHEVY VAN, 292 "Big Block 6" (will still tow)
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
jjinatx
Austin, TX, USA
Posted: 06/08/19 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
My auto switchover has started acting weird. Now, if I point the switch to a full tank, the indicator shows red, even after running appliances for quite a while. If I turn off that tank, it will switch over to the other tank like it should, but the indicator turns green. So now, green is the new red
It used to work like it should and if the tank (cylinder) pointed to ran out, it would turn red, but now it turns green. So the indicator somehow got out of sync, backwards. Anybody else have this same issue and know how to get it back in sync?
And no, I'm not an ignorant newbie, I've had RVs with auto switchover regulator for 20 years, so I do know how they work.
The switchover function works OK, so I don't think I need to change out the regulator. But getting used to green meaning empty is kind of weird.
-jj
Current Rig: 2017 F350 Crew Cab Short Bed 4X4 Powerstroke, 2018 Grand Design Reflection 29RS. Dearly Departed: 2003 GMC Sierra 3500 Dually, 2002 Bigfoot 25C10.6.
time2roll
Posted: 06/08/19 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
I recommend Cavagna brand regulator. (amazon)
675w Solar pictures back up
myredracer
Langley B.C.
Posted: 06/08/19 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
When we got our TT new, the factory had installed the regulator facing the rear so you couldn't see what tank was being used. Wan't until I flipped it around I discovered the rubber hose was too short to reach the bulkhead fitting at the front of the frame. I guess the factory was too lazy to figure it out.
At first I thought of getting a longer hose but were expensive. In the end, all I had to do was move the propane tank tray rearward a couple of inches. That was something the factory could have easily done at no extra cost to anyone. Typical... [emoticon]
Gil, Deb & Dougal a 15 year old Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH, shocks and Endurance LRE tires
2012 GMC Sierra 2500HD crew cab, Bilstein shocks, heavy duty trailering option
hawkeye-08
Northwest
Posted: 06/10/19 11:24am Link  |  Quote  |  Print  |  Notify Moderator
My Dad laughed at me when I told him I keep one tank turned off, that I manually switch over when one runs out, even though I have an automatic changeover gizmo. He doesn't laugh now as he had a propane leak, had it on auto and when the furnace died in middle of the night, both his tanks were empty. Ruined his trip (his wife was not happy).
Please note, we don't camp often enough or cold enough to run out of propane most years, so handling the switch over manually is not a big deal.
Hannibal
Tampa Bay Area
Posted: 06/10/19 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
Not too long ago my neighbor came over to tell me my TT was hissing and smelled strongly of propane. The auto switchover regulator was leaking. I shut off both tank cylinder thingies and ran drove 44 miles to the nearest Camping World for a new one. Oddly, they didn't have the yellow tape thread sealant for gas connections. Had to find a Home Depot for that. We got lucky that day as the fridge was on gas and the wind was blowing the leaking gas toward it. No gas smell now. The new regulator works great. I have both cylindrical shaped portable tanks on and rely on the red flag to refill, checking every three or four days. Get that leak fixed. A propane explosion can obliterate a TT and it's occupants.
'10 F250 XLT CC SB 5.4L 5spdTS 3.73 103k miles
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'. Reese HP Trunnion 800
OleManOleCan
Alabama
Posted: 06/13/19 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
Lwiddis wrote:
I just use one until it’s empty and switch over. Then I remove the empty one, load it in the Tahoe and find a place to fill it. No one uses that much propane. If you smell propane anytime except when filling or removing a tank, get it fixed pronto.
I had the same problem when I bought my latest camper.
Close examination showed the hoses were only half assed screwed into the tanks.
I removed them, put a little plumbers tape on the threads and installed them correctly. No problem... (Cheap fix)
SoundGuy
S Ontario
Posted: 06/13/19 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
I've always run dual tanks the same way - manually, one at a time. He who laughs last laughs best. [emoticon]
time2roll
Posted: 06/13/19 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
No thanks. After a few times swapping tanks in the middle of the night I installed an automatic and life has been wonderful ever since.
Page of 6
