RV.Net Open Roads Forum: Fifth-Wheels: Truck Question - duallie or single?
 > Truck Question - duallie or single?
Page of 9
irollman
Carlsbad, NM
Posted: 10/07/18 01:10pm Link  |  Print  |  Notify Moderator
I'm considering purchasing a 5th wheel to replace my Class A. It would be a full-timer rig, so it won't be hauled a lot. But I'd end up using the truck as a daily driver, or mostly so. Looking to get a 1-ton, as I'm looking for a more comfy 5er, which means bigger.
So, would a rear end with single wheels do OK, or is that a real no no, and should I go duallie?
Mfan
Otsego,Mi
Posted: 10/07/18 01:24pm Link  |  Print  |  Notify Moderator
Go dually. I've had both. Bigger the trailer, the bigger the truck
2oldman
New Mexico
Advantage/disadvantage dually
dually or no 2011
More dually w/5er 2011
Dually vs single 2014 in fivers
BB_TX
McKinney, Texas
Posted: 10/07/18 01:55pm Link  |  Print  |  Notify Moderator
It all depends on the total weight and loaded pin weight of the 5er and the tow rating and payload rating of the truck. Payload ratings of pickups have increased a lot over the years. And an SRW can adequately and safely tow a large 5er. But at some point the pin weight will dictate a DRW. Do your homework and check trailer and truck numbers carefully. An SRW tows a 5er very well and stable if the numbers are right. But a DRW is needed if the weight gets too heavy.
Crestview area, Inyo County, California
Posted: 10/07/18 02:34pm Link  |  Print  |  Notify Moderator
Buy or select the TT or 5er first then match a TV to it. May be SRW and may not.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
irollman
Carlsbad, NM
Posted: 10/07/18 03:41pm Link  |  Print  |  Notify Moderator
2oldman, thanks, those were interesting reads. As one of the posts said, it's all about math. I'm an engineer, so that should make the decision making process easier for me.
Thanks!
sgfrye
north carolina
Posted: 10/07/18 06:36pm Link  |  Print  |  Notify Moderator
Dually
And you won't have to second guess if you find a 15k fiver that you love.
Cummins12V98
on the road
Posted: 10/07/18 06:51pm Link  |  Print  |  Notify Moderator
When things go to **** a Dually will be the one you want.
* This post was edited 10/08/18 08:24am by an administrator/moderator *
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
larry barnhart
wenatchee. wa usa
Posted: 10/07/18 06:57pm Link  |  Print  |  Notify Moderator
same thinking for me
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
C Schomer
Pueblo West, Co.
Posted: 10/07/18 08:08pm Link  |  Print  |  Notify Moderator
If in doubt... get a dually!
Page of 9
