RV.Net Open Roads Forum: Cat C7 350 in a Winnebago Journey
 > Cat C7 350 in a Winnebago Journey
DouglasBriggs
Vassar, Michigan
Posted: 10/09/18 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
I am looking at possibly buying what I think is a late build '04 Journey 39K with 3 slides and a Cat C7 350 with 45,000 mi. The reason I say late build '04 is because I can't find specs on an '04 that match this motorhome but can find '05's that match. The owner says it's an '04. I have read a lot about this motor and it seems the HEUI fuel injection sytem can be very problematic. I have also read where owners say don't worry about that motor if you like the coach buy it. We really like the looks and the floor plan on it. Is this one I should stay away from because of the motor ?
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 10/09/18 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2005 Fleetwood Excursion 39S with the C7 and about 74,000 miles without any engine problems. There's a lot of these engines out there and I haven't heard of any problematic fuel problems with them in the six years I've owned this MH.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
Mandalay Parr
Phoenix, AZ
Posted: 10/09/18 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Never any issues with mine in 90,000 miles.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
jplante4
Cape Cod
Posted: 10/09/18 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
150,000 on my 3126B with HEUI and no issues.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
cableguy574
Fairfield Glade, TN
Posted: 10/09/18 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
I have 2008 National Pacifica with a C7 with 52000 miles going strong
2008 National Pacifica V36a
2014 Jeep Wrangler /Brake Buddy
JUST Me & My wife & dogs ">
FMCA 387898
A member of NUTS
Big Katuna
Deland, FL
Posted: 10/09/18 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
I’m sneaking up on 60K miles no major issues. Turbo boost sensor wiring problem.
I’ll be bold and say that most brands will give you problems if not used regularly and maintained properly.
These motors were designed to be used.
My Kharma ran over my Dogma.
FIRE UP
Lake Havasu City AZ
Posted: 10/09/18 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
DouglasBriggs,
I'd sure like to find all these folks that say stay away from a CAT engine due to it having the HEUI system. As I understand it, CAT isn't the only engine builder that's used it. But, in any case, the CAT engine, specifically the C-7, along with it's infamous HEUI system, is not and was not, only installed in motorhomes but, also cement trucks, fire trucks, over the road trucks, local delivery trucks and a whole lot more.
And guess what, a very, very large percentage of them are still running around today. As you can already read from the responders here, many have lots of miles and great years of travel with their CAT engine equipped coaches, including ours, an '04 Itasca Horizon 36GD with the CAT C-7 330HP. We have at present, right at 84,000 miles on ours. I've done the fan bearing, serpentine tensioner bearings, idler bearings, water pump, "regulators" as CAT calls them, belts, and a few other items on that motor.
Your potential Winne Journey and our '04 Itasca Horizon, are pretty close in similarities. I could go on for pages but, I won't bore you unless you ask. It would be nice if you could obtain any form of maintenance records with that coach. But, if not, it's not the end of the world. Many of us have purchased these rolling Kleenex boxes with less than preferable supporting paperwork. For the most part, all of them are still rolling down the road.
There's lots to check out on that Winne. A very important first line of inspection, on a coach of that age is, the roof-to-gutter seam/seal/joint. It travels long the edge, for full length, on both sides. And, Winne and Itascas roofs are fiberglass and are only held in place by an adhesive caulk/sealant. After time, and a few zillion miles, that joint has tendency to start to come loose.
You can tell if it is by getting on a ladder, CAREFULLY, and, climb up to a point you can inspect that seam. You press on the fiberglass section of the roof, just above the caulk/adhesive. If you can press the fiberglass away from the sealant, NOT GOOD! You do this inspection, for the full length on both sides, noting any where it may be separated. To fix this situation, that's a whole 'nother set of pages here.
But, there's also lots of other areas to inspect. If you'd like help, just ask. There's tons of experience on this forum that are always more than willing to help. Good luck and, don't worry about the CAT, it's a great engine.
Scott
Scott and Karla
SDFD RETIRED
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
Scottiemom
South Dakota/Indiana
Posted: 10/10/18 04:30am Link  |  Quote  |  Print  |  Notify Moderator
We have a Cat C7 350 in our 06 Tiffin Phaeton we bought new. We have 138,000 miles on her, all fulltiming miles. We had to replace the injector cup seals and a belt, but we've been trouble free most of those miles. Very dependable.
Dale
Dale Pace
Wife to Terry (Teacher's Pet)
Mom to Scottish Terrier, Duchess
2006 Tiffin Phaeton 40'(Phaeton Place)
2014 Ford Flex
2004 R-Vision Trail-lite 213 (MinnieMee)
Fulltiming since 2005
http://www.skoolzoutforever.blogspot.com/
Where are we?
ncrowley
Utah
Posted: 10/10/18 06:29am Link  |  Quote  |  Print  |  Notify Moderator
We have a Cat C7 350 and the HUEI pump went out. The injectors has to also be replaced because when the pump goes, it puts out metal shavings. Thank goodness our extended maintenance plan covered it. It went out at about 45K miles.
We take very good care of the coach bbut we do not know how well the previous owners cared for it.
That said, it has been a very good engine and I would not hesitate to purchase another one with that engine.
Nancy
Newmar Northern Star
Belgique
Hickory, NC
Posted: 10/10/18 06:44am Link  |  Quote  |  Print  |  Notify Moderator
What I've learned about the HUEI from old hands is change oil at around 6K miles rather than the CAT schedule of 11K. Seems like good insurance to me.
Hickory, NC
2007 Fleetwood Discovery 40X
