RV.Net Open Roads Forum: Cat C7 350 in a Winnebago Journey
 > Cat C7 350 in a Winnebago Journey
DouglasBriggs
Vassar, Michigan
Posted: 10/10/18 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the replies. I have read about changing oil way ahead of Cat's recommended change. I do realize there is a risk with any used motorhome so maybe just go with a floorplan we like. I also did some research and can't find the UVW of that 39K Journey we want to look at. Anybody have that info ?
FIRE UP
Lake Havasu City AZ
Posted: 10/10/18 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
UVW?
Also, you have a PM
Scott
Scott and Karla
SDFD RETIRED
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
DouglasBriggs
Vassar, Michigan
Posted: 10/11/18 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
Unloaded Vehicle Weight. The GVW on a 2004 Journey 39k is only 27,900 so it would be nice to know how much cargo you can load in it. My 2001 Adventurer 35u(which I just sold)had a chart with it that had the unloaded weight on it. We owned that coach for over 12yrs and had very good luck with it. Very well built. Never had to replace anyplace but tires. Oh, did replace bedroom slide hoses but that was due to HWH defective hose ends.
FIRE UP
Lake Havasu City AZ
Posted: 10/11/18 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
Your spec placard, that's attached to the wall, right alongside the drivers seat, tells you all the specs for your coach. You say its GVWR is 27,900, well, it's actually 27,910. Your rear GAWR is or should be, 17,500. Your front GAWR is 10,410. So, together, you're looking at 27,910.
As for your UNLOADED VEHICLE WEIGHT, well, that's easy, go weigh it. Put what you normally carry in it in terms of fuel, water, tools, chairs, equipment, and any supplies that you'd normally travel with and go weigh it. You'll come up with a figure that you'll either subtract from the GVWR or, you'll be very close to that GVWR or, possibly be OVER the GVWR. I've been over on mine quite a few times. Still rolling down the road.
Scott
DouglasBriggs
Vassar, Michigan
Posted: 10/11/18 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have the motorhome yet. We are going to look at it hopefully Saturday and I will see what it is then.
keepingthelightson
Santa Clarita, Ca
Posted: 10/13/18 10:07am Link  |  Quote  |  Print  |  Notify Moderator
Maintenance, Maintenance, Maintenance. I purchased our Phaeton with 41k C7 CAT 350. I changed ALL the fluids, belts, shocks, gen maintenance, etc. No records from previous owners. I had CAT do the valve adjustment. CAT says at 30k, then again at 100K. I only use 5/40W Rotella and CAT filters. It's been a good engine for us, now with 64K.
Good luck [emoticon]
05 Tiffin Phaeton 40 QDH w/4 slides
CAT C7 350+ HP MP-8, Aero Muffler, AFE Filter
06 HHR LT Toad
Ready Brute Elite
cbeierl
Nashua, NH
Posted: 03/12/19 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
Here's a thread (over on iRV2.com) describing this filter mod: HEUI Pump Failures
It can't prevent a problem with the HEUI pump, but it does protect the the fuel rail and injectors if a problem does occur with the pump--thus limiting the repair cost considerably. Although I've not had any problems at all myself, I'm certainly considering this for the C7 in my 2005 Vectra as extra protection.
* This post was edited 03/13/19 10:31am by an administrator/moderator *
Chris Beierl
2005 Winnebago Vectra 36RD
