RV.Net Open Roads Forum: General RVing Issues: Using fridge in feezing temps
 > Using fridge in feezing temps
luberhill
syracuse
Posted: 10/20/18 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
Any issues on gas or electric when outside temp is below feeezing
2013 Winnebago Sunstar 26HE
GordonThree
Northern Michigan
Posted: 10/20/18 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
How far below freezing?
30s overnight no probs
Consistent 20s at night and 30s during the day it's time to block vents and install a light bulb near the back of the unit
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
Ski Pro 3
Placerville, CA
Posted: 10/20/18 11:41pm Link  |  Quote  |  Print  |  Notify Moderator
I've camped down to 12 degrees at night with highs below freezin with no ill effects on my RV fridge. Maintains the temp it was set for and works fine.
2006 Dodge Ram 4x4 crew cab w/diesel and manual tranny.
2012 Lance 855S camper
garyemunson
Reno, Nevada
Posted: 10/21/18 05:02am Link  |  Quote  |  Print  |  Notify Moderator
We've never had issues camping in cold weather with our Norcold. That said, once the temps get to the teens, we stay home as that's pretty much where the RV stops being comfortable inside. While the furnace will keep the temp OK, you can just feel the cold near the walls and windows and it starts being a real chore to keep the water/sewer working right. If we're not comfortable, camping stops being fun!
noteven
Alberta
Posted: 10/21/18 06:01am Link  |  Quote  |  Print  |  Notify Moderator
A few nights Dec16 / Jan17 at -36. Dometic model 3962? - trailer connected to shore power at the time. Fridge kep on working normally.
Continuous living in those temps I would maybe find a porous non combustible material to pad the vent door to reduce the direct icy blast of air during an OMG Polar Vortex Event / Warning / Advisory.
Had to put a little electric cube heater by the propane cylinders and throw an old blankie over them to keep the propane boiling.
BobsYourUncle
Calgary Alberta Canada
Posted: 10/21/18 07:07am Link  |  Quote  |  Print  |  Notify Moderator
I lived 2 winters in my TT in Alberta.
In the minus 20's for weeks on end the refer was ok.
Had a few issues when it got to about minus 33 C. I had to block the bottom air intake and put a 100W light bulb in the back to warm up the back of the fridge to keep it running.
Also had to put a heating pad in with my propane bottles to keep enough flow to run stuff, especially the furnace.
At a few degrees below freezing your fridge is absolutely a non issue. Don't even think or worry about it.
Dmax/Allison
1997 Triple E Topaz 27' Bunkhouse TT
I do
Precision Guesswork
based on
Vague Assumptions
Unreliable Data of Dubious Accuracy
provided by persons of
Questionable Intellectual Capacity
Now, What would you like done?
missourijan
Tucson, AZ
Posted: 10/21/18 08:01am Link  |  Quote  |  Print  |  Notify Moderator
X2 on what GordonThree said. Ours froze one winter in Carson City, we had to replace the cooling unit. What a pain
pianotuna
Regina, SK, Canada
Posted: 10/21/18 08:35am Link  |  Quote  |  Print  |  Notify Moderator
There is a wonderful thread on winter camping in the full time forum. Norcold does have a cold weather kit that can be added.
I use a thermocube and a 60 watt bulb and do restrict the air flow in the worst part of the winter.
An ounce of protection is worth a pound of cure.
Regards, Don
Dennis12
Ridgeley WV
Posted: 10/21/18 11:17am Link  |  Quote  |  Print  |  Notify Moderator
As long as there is some heat in the camper you should have no problem. If not like was said above install a light bulb near the back of the unit. There is a receptacle in there for that.
Dennis Hoppert
memtb
Wyoming
Posted: 10/22/18 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
We went thru two Wyoming winters, living in our 5th wheel, with numerous -30 F ( or slightly colder).....no special provisions made and no problems with the fridge!
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
