RV.Net Open Roads Forum: Dinghy Towing: Jeep toad rides to rough.
Search only in Dinghy Towing
 > Jeep toad rides to rough.
Page of 7
Trigger Happy
So. Calif.
Posted: 10/25/18 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Our toad is a 06 Jeep LJ Wrangler Unlimited. It a great vehicle for towing but when driving it the ride is to rough. It's not lifted, has all stock suspension and tires. We don't go off road with it, it's more a daily driver type.
It rides like a Jeep ( [emoticon] ) but if anything can be done for improving the ride I'd like to try.
Anyone have any success at this?
Big Katuna
Deland, FL
Posted: 10/25/18 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
Not much one can do. If your not off roading, street tires might help. Softer shocks, maybe adjustable.
I had two Jeeps, liked them, seldom went off road, went with Honda CRV s and finally Element..
My Kharma ran over my Dogma.
2oldman
Salton Sea
Posted: 10/25/18 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
Riding too rough may be helped by airing down the tires a bit.
Sam Spade
North Central Florida
Posted: 10/25/18 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
Key words are "a bit".
You should NOT go below the original recommended pressure more than a couple of pounds though......and not likely that will make much difference. The recommended pressure is what is on the placard inside the door jamb or in the owners manual; NOT what it says on the sidewall of the tire.
Also, if the tires are original equipment, they are 12 years old now and probably are getting HARD just from age......and probably were stiff to start with.
It is generally accepted that tires should not be used after about 7 or 8 years and become dangerous after 10. Highway tires, that is.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
mike brez
milford ct
Posted: 10/25/18 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
A 2006 LJ [emoticon]
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
Death Valley!
Posted: 10/25/18 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
I believe airing down as 2oldman suggests might help.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
travisc
Pacific NW
Posted: 10/25/18 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Do you a hard or soft top? You can get a lot of different spring options for that. You might want to consider some different shocks, how many miles on it? I have an 06 lj rubicon also
Winnebago Access 24V
travisc
Pacific NW
Posted: 10/25/18 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
Lj long wheel base tj. They made them between 04 and 06
STBRetired
I-80 and I-55
Posted: 10/25/18 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Don't air down the tires too much. They can overheat while going down the road.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
WAFlowers
Clearwater, FL
Posted: 10/25/18 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
And that's why we tow a Jeep Grand Cherokee with QuadraLift and QuadraTrac II. Maybe I can't do the extreme rocks but it does quite well on the trails I want to ride.
Not all Jeeps ride the same. And not all Jeeps are Wranglers.
Bill and Willemina Flowers
George, Sammy and Teddy (the dogpack)
2008 Tiffin Phaeton 40QSH
2005 Keystone Monata 3400rl (5/21/11 to 9/9/17)
(Was in a 2000 Coachmen Catalina Sport 220RK)
Page of 7
