RV.Net Open Roads Forum: General RVing Issues: Which batteries do I buy.
 > Which batteries do I buy.
gmctoyman
Lake Livingston, Texas
Posted: 10/28/18 08:50am Link  |  Quote  |  Print  |  Notify Moderator
If you boondock you might be interested in this thread.
Clicky
* This post was edited 10/28/18 09:44am by an administrator/moderator *
Dave W. AKA "Toyman"
KE5GOH - On 146.52
RV's ? What RV's ???
Apache Pop-up
Classic GMC Motorhome
07 Leisure Travel Sprinter
Do Boats Count ?
travelnutz
West Michigan - On the Lakeshore
Posted: 10/28/18 09:52am Link  |  Quote  |  Print  |  Notify Moderator
There's a lot more pertinent info to know as to which RV batteries are the smartest to purchase and use in RV's. Also depends if you have physical room for 1, 2, 3, 4, 5, 6, or even 7 batteries in your RV. Always smarter to only use deep cycle batteries as they have thicker plates inside and can be recharged a lot more times before battery failure occurs.
The odd number of batteries means to get maximum amperage delivered before needing to be recharged usually at 50% of battery capacity remaining and that's important. The same goes for both 6 volt golf cart type batteries (2 always req'd to make 12 volts) and 12 volt deep cycle marine batteries (each battery gives 12 volts.
For instance, you can't have (3) 6 volt GC batteries connected together to give 12 volts so only 2 can be connected giving 12 volts which then only gives the same total amperage capacity at 12 volts as a single GC 6 volt battery. 200 amps at 6 volts capacity and then connecting 2 together to double the voltage to 12 volts still only has 200 amps capacity, period! However, having room for 3 12 volt 100 amp capacity batteries actually gives 300 amps of capacity. 1-1/2 times the using of (2) 6 volt GC batteries in the same available physical space location.
With (2) 6 volt GC batteries and one fails you have ZERO usable 12V DC power at all. All circuits are unusable, period! With any number of 12V batteries and if all but one battery were to fail, you still will have all circuits powered and completely usable. Simply unhook any or all the failed batteries and just carry on with your life!
Our 5th wheel has 5 group 31 12V deepcycle batteries inside the front basement vented storage battery area and each of the all alike batteries have 120 amp capacity and thus there's 600 amps total capacity. Also defined at a 23 amp draw for 225 minutes each capacity. That's a total of 1125 minutes of a constant 23 amp draw capacity! The batteries also power our 2500 watt inverter and have never drawn the batteries below 50% yet. The joys of having adequate amps stored onboard!
All 5 batteries were all purchased at the same time and from the same place in June of 2010 and the cost was $92.61 each + 6% sales tax on sale here in Michigan less that 2 miles from our home and are still going strong yet today and we will wait until spring 2019 to replace them when we get back from our annual 2-1/2 months down in Florida. The will looking for them on sale again, Why not? 2 months ago the same batteries were on sale at the same place here for $99 each and almost bought 5 of them again there but decided to wait until next year and will buy 8 of them as will need to replace the 2 In the bed of our truck for the Lance TC and the one in the Lance TC which all 3 are wired (cabled) together as the Lance has a 1500 watt inverter inside and gives us 360 amps of capacity.
Years past, were had 2 RV's with GC batteries paired and they lasted absolutely NO longer than the 12V DC Marine Batteries at ALL before needing to be recharged. So now only use just 12V batteries as it makes so much better sense and they are available anywhere if needed.
To each his own!
A superb CC LB 4X4, GM HD Diesel, airbags, Rancho's, lots more
Lance Legend TC 11' 4", loaded including 3400 PP generator and my deluxe 2' X 7' rear porch
29 ft Carriage Carri-lite 5'er - a specially built gem
A like new '07 Sunline Solaris 26' TT
Boon Docker
Mountain Foothills of South Western Alberta
Posted: 10/28/18 10:14am Link  |  Quote  |  Print  |  Notify Moderator
The magic of 12v batteries in parallel.
If one fails the good one will disconnect itself automatically so it does not get discharged by the one that failed. [emoticon]
pnichols
The Other California
Posted: 10/28/18 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
How true that "disconnect itself" is ... except it's the bad one that "disconnects itself" from the battery(ies) in parallel with it ... not the good one(s).
My experience over the years with failed 12V batteries is that they fail by going to "an open" ... not to "a short" such that any others in parallel with the bad battery would thus experience a high current rapid discharge ("explode"). From all I read, whole battery internal shorts are not a common failure mode for either 12V or 6V batteries.
The best way to short any lead acid 12V or 6V battery and explode it is to drop a wrench, or cats paw, or crowbar, or etc. across it's positive and negative terminals. That's called a whole-battery-exterior-short ... and can be very dangerous indeed.
Phil, 2005 E450 Itasca Spirit 24V
Wherever I happen to park
Posted: 10/28/18 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
GordonThree wrote:
Parallel batteries get used a lot, I don't see it all over the news about them exploding. Have a citation you can share?
You are making an assumption
you see "Exploding" and you think KABOOM!!!!! and bent metal and stuff flying.
What we mean when a battery "Explodes" is more likely a "POP" and acid all over the battery compartment. No bending of metal. just eating away of it. It is still and "Explosion" by definition but not a violent one.
I do not know that a battery in parallel with another will "expload" when one goes bad and I do run 4 parallel batteries (one of which is 2 six volt in series) but explosion protection is in place.
Eventually I will be all 6 volt's likely 3 pair total. but 2 pair for sure.
The big difference is the GC class batteries are DESIGNED for RV use and the Group XX are not.
Home is where I park it.
time2roll
Posted: 10/28/18 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
A pair of GC2 will serve you well in most conditions and use patterns.
Have you had any issues with the current battery set up?
675w Solar pictures back up
GordonThree
Northern Michigan
Posted: 10/28/18 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
Theres a lot of assumptions being made about the likelihood of catastrophic failure.
If it were such a common problem there'd be a lot more relevant information about it. Rather than conjecture and third hand information.
For the hand wringing group you could use fusible links to parallel the batteries.
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
theoldwizard1
SE MI
Posted: 10/28/18 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
Everyone has an opinion on batteries ! My un-scientific poll says the majority of people would recommend two deep cycle 6V golf cart batteries. The cheapest source is either Costco (Interstate) or Sams Club (Duracell made by East Penn). Lots of good reports on both.
Only you will know if this is adequate for your needs. (Fine for lunch stops or one night of boondocking without a residential refrigerator or A/C.)
Consider upgrading you converter. Most "stock" converter do not do a good job charging your house battery bank.
CincyGus
Cincinnati
Posted: 10/28/18 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
I went with two 12v Trojan 1275's in parallel. Pricey but plenty of AH's (150 AH each), true deep cycle and well know in the golf cart world to last 5-6 years with good maint (Adding Water, not discharging below 50%). I don't have any of the worries of if one goes out, not being able to run my 12v stuff and gain the benefit of the more AH's and the true deep cycle most move to 6v batteries for. My camper has an 11cf residential fridge on an inverter and I wanted to extend the time between running the genny when boondocking as much as my battery tray would allow.
2015 GMC 2500 Denali Crewcab 4x4
2019 Forest River Wolfpack 23pack15
Hope your travels are safe and the friendships made camping are lasting.
azrving
Oatman
Posted: 10/28/18 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
Trojan says 14.8 volts bulk charge. I charge my Sams club to 14.8 on solar and 14.4 on PD4655.
