RV.Net Open Roads Forum: Tech Issues: LifePO4 batteries
 > LifePO4 batteries
Page of 7
theoldwizard1
SE MI
Posted: 10/31/18 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
Full time mostly off-grid... lithium is looking like a good value.
From the "off grid" YouTube channels I watch, NOT ONE use LiFePO4. MASSIVE lead acid battery banks (eight or more GC2 or some othe sized lead-acid) because size and weight are NOT an issue for them. Cost is !
48VDC @ 200Ah+ is a lot of storage capacity. Most off gridders try to not go below 80% SOC.
gmctoyman
Lake Livingston, Texas
Posted: 10/31/18 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
Nuff said, even if they are way high on the cost of LA batteries.
Click
Dave W. AKA "Toyman"
KE5GOH - On 146.52
RV's ? What RV's ???
Apache Pop-up
Classic GMC Motorhome
07 Leisure Travel Sprinter
Do Boats Count ?
time2roll
Posted: 10/31/18 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
OK and I see plenty on YouTube with drop in batteries, used Tesla batteries, used LEAF batteries, home made BMS, home made heating system, and all kinds of high tech.
675w Solar pictures back up
azrving
Oatman
Posted: 10/31/18 10:20pm Link  |  Quote  |  Print  |  Notify Moderator
* This post was edited 10/31/18 10:34pm by azrving *
mchero
Henniker, NH
Posted: 11/01/18 03:52am Link  |  Quote  |  Print  |  Notify Moderator
MASSIVE = cost in my books. Especially if we are talking FLA batteries. I have seen some mighty pricey battery banks RUN FLAT in many diesel coaches I worked on in Quartzsite AZ.
Owners wondering why the house batteries are not holding charge like they should. Cost to most is not an issue.
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 11/01/18 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
I can see it now department.
Spending five thousand dollars on lithium
Only to have
"Brand new battery technology! No discharge or charge limits. Battery can remain at 0% charged for months with no degradation. No intracell management system needed. Can tolerate charging limit to 16 volts without damage. Costs twice as much as lithium but 100% guaranteed for 20 years. Operates and charges effectively at -40F -40c
mchero
Henniker, NH
Posted: 11/01/18 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
Only to have
Five Thousand Dollars? Where are you getting those numbers? You have got some reading to do.
2 Battle Borne 100Ah 12V GC2 LiFePO4 Deep Cycle Battery at 1,049.00 each and one Xantrex Freedom XC 2000 watt true sine wave inverter/charger at 569.00 equals 2,667.00.
FAR from Five Thousand.
I'd say prices are indeed dropping!
MrWizard
Traveling
Posted: 11/01/18 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
you missed it..
NOT talking lithium
making speculative advert for battery tech replacing lithium
Radiate The Happy
1997 F53 Bounder 36s
mchero
Henniker, NH
Posted: 11/01/18 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
MrWizard wrote:
you missed it..
NOT talking lithium
Oh, sorry, I read "Spending five thousand dollars on lithium"
My Xantrex Freedom 458's FLA charge setting will NOT fully charge my Interstate house batteries. BUT the Xantrex Freedom XC has a programmable, configurable 3 stage temperature compensated battery charge algorithm!
A great first step towards a iithium house battery setup!
MEXICOWANDERER
Posted: 11/01/18 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
Just about the time arrives for "affordable lithium" and the tree I am feeding grows ten feet, there will arrive new batteries. The chances of having twenty or thirty astonishing superior promising technologies prove fruitless is quite small in my estimation.
500 usable amp hours is not huge. A 1,800 square ft. home would need 50 times that to be basically outfitted. With induction stove and space heating it would have to be 500 times that A 40 ton A/C unit requires how many kWh over 24 hours, you say?
Page of 7
 > LifePO4 batteries
