RV.Net Open Roads Forum: Fifth-Wheels: Gas Cylinders
 > Gas Cylinders
stickdog
Somewhere, USA
Posted: 11/01/18 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
The recert is good if you don't plan on refilling tanks on a trip through Canada. Their recert is much more intense than what you'll receive from your local supplier.
9-11 WE WILL NEVER FORGET!
17 MS 36 RSSB3
Gone 04 HH DA LS 33.5 RLTG
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
time2roll
Posted: 11/01/18 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
costco.com sells 30 pound replacements fairly low cost.
675w Solar pictures back up
Old-Biscuit
Verde Valley
Posted: 11/01/18 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
Re-cert 12 yrs after date of MFG stamped on collar.
Visual re-cert good for 5 yrs then repeat AS MANY Times as you need.
Cylinders do NOT wear out.......they get damaged, rusted up etc but can be re-cert MANY MANY times.
rhagfo
Portland, OR
Posted: 11/01/18 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
greende wrote:
I would get #30 recertified. #20 cylinders are easier to exchange at HD, Lowes etc and the clerks often let you paw through the cabinet to find the latest date. That is (out of date) a valid reason to exchange per the exchange companies.
Well I took my empty tank to the local full service Propane supplier. The valve assembly failed on both tanks (leaked) cost of new valve was only $20 less than new 30# tanks, so replaced both.
Took DD's 20# tank to same location as it was past date, and exchanged it for a new tank with likely 15# of propane, but the tank was brand new.
Ava
Vancouver Island. BC Canada
Posted: 11/01/18 10:45pm Link  |  Quote  |  Print  |  Notify Moderator
Portable tanks are only good for ten years in Canada.
SidecarFlip
SE Michigan
Posted: 11/02/18 06:17am Link  |  Quote  |  Print  |  Notify Moderator
My local supplier re-certifies them for free when I fill them. I never exchange bottles.
Interesting about re-certification. all 3 of my 500 gallon bottles that supply my house and shop are at least 30 years old and have never been 'certified'.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
reluyog
Colorado
Posted: 11/02/18 07:43am Link  |  Quote  |  Print  |  Notify Moderator
I recently had our two older 40# tanks re-certified and knew they needed new OPD valves since the internal gaskets were shot. It was still less expensive to go that route. I keep 4 40# tanks with us when we're out tripping around with the camper.
Damian
1983 KW W900, 3406B Cat, RTO15, 355's
1995 Carriage by Carriage triple axle 22K
Retired JSO
Northeast Florida
Posted: 11/02/18 08:00am Link  |  Quote  |  Print  |  Notify Moderator
Stationary tanks are usually ASME tanks, not DOT.
Allworth
Orlando, FL
Posted: 11/02/18 11:21am Link  |  Quote  |  Print  |  Notify Moderator
A couple of things here (as the OP).
20# tanks do not fit my double cylinder bin. They have to be up on spacers and they bang around. So much for exchange.
I am not talking about a visual recert while getting a refill. That is good for five years and I wouldn't trust it myself.
I'm talking about a hydro-tank pressurization test (the same as used on SCUBA tanks, which I also have and use). The tank is submerged in a water vat (to absorb the blast if it explodes) and pressurized to 2.5 times the working pressure. The date and location of the test is then stamped on the collar. This is also the test for MIG welding cylinders (which I also have and use).
A
(ASME tanks, including those in most Class As, are exempt.)
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
bpounds
Sophmore Brain...
Posted: 11/02/18 11:50am Link  |  Quote  |  Print  |  Notify Moderator
30# exchanges are out there. Google it, or better, call around your area.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
 > Gas Cylinders
