RV.Net Open Roads Forum: Tow Vehicles: Dark differential lube
Search only in Tow Vehicles
 > Dark differential lube
Page of 6
Blazing Zippers
North Idaho
Posted: 11/07/18 11:17pm Link  |  Quote  |  Print  |  Notify Moderator
Being the good owner that I am---I took the Ram to a shop for its oil change. I've had LOF done there before with no issues.
This time, they said that the rear differential gear oil was "dark," and that the brake fluid needed changing. The truck has just over 26,000 miles, and about half of that was towing a trailer or fifth wheel.
I'm not a mechanic, but I've never had to do either of these things. In fact, I don't recall anyone I know changing these fluids except when disassembling their vehicle. Has this shop turned into a "stealership?"
Your thoughts please.
LanceRKeys
Amarillo, TX
Posted: 11/07/18 11:43pm Link  |  Quote  |  Print  |  Notify Moderator
What does your owners manual say about it?
K-9 HANDLER
Maryland's Eastern Shore
Posted: 11/08/18 03:00am Link  |  Quote  |  Print  |  Notify Moderator
how old is the truck
Camping near home at Assateague National Seashore with our wild four legged friends
jfkmk
NJ
Posted: 11/08/18 03:17am Link  |  Quote  |  Print  |  Notify Moderator
Both the above questions are applicable. Diff fluid usually has a much longer life, closer to 100k miles. Brake fluid should be changed out every 3 years or so. But, when in doubt, follow the owners manual.
Ralph Cramden
US
Posted: 11/08/18 03:22am Link  |  Quote  |  Print  |  Notify Moderator
Changing brake fluid? LOL.
Esepcially so at 26K miles.
I've had 3 trucks since the mid 90s I took to over 200K and never changed brake fluid. What a waste.
Well on one the brake fluid was changed at about 240K when I replaced all the brake lines due to road salt corrosion but the only new fluid ever put in was topping off after replacing pads / shoes.
I vote they are reaching into your pocket seeing what they can grab.
I would also guess RAM is using synthetic fluid in the diff? 26K miles? LOL.
But then again you have a lot of people on RV or truck boards who take fluids and when to change them to the point of anality. Send the brake fluid and gear oil off to some lab somewhere for analization and piss away some more money.
ib516
Way up north eh
Posted: 11/08/18 04:08am Link  |  Quote  |  Print  |  Notify Moderator
Follow the maintenance schedule in the manual.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
All above are sold
Current: 07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
gbopp
The Keystone State
Posted: 11/08/18 04:35am Link  |  Quote  |  Print  |  Notify Moderator
Did they say if changing the fluids was a manufacturer recommendation or a ' dealer' recommendation?
There is a difference.
p220sigman
Tallahassee, FL, USA
Posted: 11/08/18 06:00am Link  |  Quote  |  Print  |  Notify Moderator
Did they tell you your muffler bearings weren't looking good either?
Unless the brake system was compromised somehow and the fluid contaminated, it is very unlikely it would need to be changed at 26K miles. Unless you towed really heavy and got the rear diff smoking hot, it is also very unlikely the fluid would need to be changed either. Sadly, it sounds like they are trying to relieve you of as much of your money as possible.
I've had a dealership straight up try fraud on me. I took my car in for routine service. I buy my air filters in bulk and change them myself so I never need the air filter service part done. It just so happened I had changed the air filter 2 days before taking the car in. When I checked the car in with the service writer, I let him know that the air filter was fine and would not need checking or changing. Low and behold, a different service person came to me in the waiting area and said "I know you said the air filter was good, but we always check anyway and your filter does need replacing." I said "Really? Please let me see the old one" I always write the date I change the filter on it in permanent marker. He brings me this caked up nasty filter that isn't even the right filter for my car. I ask him, so this came out of my car and include the year/model of car. He says yes, I just took it out. When I asked to let's go see the air box, he gave me the song and dance about insurance regulations. When we had the service manager present, I then informed both that the filter had been changed personally by me 2 days prior and that the filter he showed me did not even fit my car. The service guy had the deer in the headlights look and the service manager managed to get out an apology saying the service guy must have mistaken my car for a different one before having an urgent issue he needed to address. At least I got a free service out of the deal. I don't know what happened to the service guy, if anything as I never went back to that dealership (even when we bought a car of the make they sell) after that. I told this story to say a mechanic you can trust is worth their weight in gold.
Mike LeClair
Wetaskiwin, Alberta
Posted: 11/08/18 06:04am Link  |  Quote  |  Print  |  Notify Moderator
Your oil change shop is simply surfing in your wallet/pocketbook. Just stick with what the manufacturer suggests in your owners manual and you will be fine.
Cheers!
Mike
Something Old, Something New
2012 F350 SRW, 6.7l Powerstroke, 3.55's front and rear.
2008 Fleetwood Regal 325RKTS
Mike, Carol and our 4 legged "furry child" Kenzie Shweenie Tod
Groover
Pulaski, TN
Posted: 11/08/18 06:22am Link  |  Quote  |  Print  |  Notify Moderator
Brake fluid can go bad although but in my experience has obvious visual indication. Bad fluid can lead to sticking calipers and expensive brake repair. To be on the safe side I would ask why they think that it needs to be replaced. If they say that it has been contaminated I would pull a couple of samples at the calipers and do a visual inspection myself. Fluid will generally gravity flow through the system so if you are patient you can easily change it yourself just by opening the bleed at the caliper and keeping the reservoir full. A few pumps of the brake pedal will accelerate things. Be sure to catch the mess and don't get any on the paint!
Page of 6
