RV.Net Open Roads Forum: Tech Issues: T-connector for hot water heater
 > T-connector for hot water heater
motc777
Posted: 11/08/18 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Suburban Hot Water Heater. The T-Connector on the back is leaking. Now, I unscrewed it and put some pipe tape on there, but what I found out is that as you look at this picture, the end that connects to the elbow on the back of the hot water heater tank, the inside seal is falling out.
I want to replace this T-connector, but for the life of me, I cannot find it online. I don't even know if I am searching the right thing. As you can tell, it's threaded on the left, the bottom, but on the side that connects to the elbow, the actual connector is fixed to the Tee. Help!
Smoke me a kipper. I'll be back for breakfast! - Ace Rimmer
time2roll
Posted: 11/08/18 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
Search 'Flair-it' fittings
https://www.completemobilehomesupply.com/Flair_It_Fittings_s/25.htm
675w Solar pictures back up
Old-Biscuit
Verde Valley
Posted: 11/08/18 11:34pm Link  |  Quote  |  Print  |  Notify Moderator
Or ....
Take the old seal to an ACE Hardware and get a replacement seal
agesilaus
North Florida
Posted: 11/09/18 06:56am Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
Or ....
Ditto or one of the big box hardware stores. I doubt those plastic fittings seal on the thread so teflon tape is probably not effective.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
dougrainer
Carrolton, Texas
Posted: 11/09/18 09:40am Link  |  Quote  |  Print  |  Notify Moderator
This is what you need. Doug
https://www.rvplus.com/flair-it-santopre........R9N_H3gIVCMJkCh0dWgnJEAQYASABEgKhe_D_BwE
Wherever I happen to park
Posted: 11/09/18 09:59am Link  |  Quote  |  Print  |  Notify Moderator
If you had ask this a month ago.> i'd not know what to tell you
That is a FLAIR it Connector for PEX any decent RV store should have (The better ones) I know General RV does.
https://flairit.com/
T-Fitting
NOTE the T fitting I linked to may be the wrong one.
Rachel (The RV GIRL) just put one in my plumbing
She slipped the NUT over the pex.
Then she used a special tool to slightly Enlarge (Flair) the end of the pex
THen shoved it onto the T and tightened it down. Job done. No leak.
Home is where I park it.
Z-Peller
Oceanside BC
Posted: 11/09/18 11:54am Link  |  Quote  |  Print  |  Notify Moderator
That fitting is there in first link given to you.
Flair-It 1/2" Swivel by 1/2" by 1/2" Tee
Connect a 1/2" male threaded pipe to 1/2" PEX or Polybutylene tubing, with another 1/2" tube teed perpendicularly with the Flair-It half-swivel-half-half tee compression fitting.
1/2" female connection and 1/2" cone tube connection on opposite ends
1/2" cone tube connection on the top
Flair-It Half Swivel by Half by Half Tee Shipping and Delivery
CompleteMH delivers the half swivel by half by half inch tee from our warehouse directly to your door. For shipping rates to your location, add the mobile home half swivel by half by half inch tee to your Cart, enter your zip code, and click Recalculate. Choose Ground or Expedited delivery depending on your needs, and we'll get your order shipped right away!
Flair-It 1/2" Swivel to 1/2" to 1/2" Tee Price Match Guarantee
Complete Mobile Home Supply proudly offers the lowest prices on thousands of parts in stock including this 1/2" swivel to 1/2" to 1/2" tee. Customers repeatedly choose CompleteMH because of our industry-leading expertise and customer service, in addition to our low prices and great value. If you find another retailer with a lower price on this manufactured home 1/2" swivel to 1/2" to 1/2" tee, contact us and we'll be glad to match it! Conditions on price match:
Bill..
2017 Bigfoot 10.4 camper...2016 GMC 3500 4x4 Xcab Duramax Dually...
drsteve
Michigan
Posted: 11/09/18 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.completemobilehomesupply.com........lf_Swivel_Half_Half_Tee_p/flairit142.htm
1991 Palomino Filly PUP
mobeewan
Hampton, Va
Posted: 11/09/18 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
1/2 inch saniprene seal 10 pk $4.25.
I keep a couple spares in my plumbing spare parts box. Came in handy when I had to keep disconnecting and reconnecting a flair-it swivel connection when I had a plumbing problem. I wound up damaging the seal.
motc777
Posted: 11/18/18 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the help guys. Got a new one on the way!
