RV.Net Open Roads Forum: Tech Issues: T-connector for hot water heater
 > T-connector for hot water heater
mobeewan
Hampton, Va
Posted: 12/23/18 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
Cross threaded? If the seals are in and everything is tight it should be okay.
drsteve
Michigan
Posted: 12/24/18 06:33am Link  |  Quote  |  Print  |  Notify Moderator
motc777 wrote:
Well got home tonight and discovered that it was leaking from the tee and the elbow. I put on the cone shaped seals on both. On the elbow leak gone! On the tee slowed but still flowing. I then lifted up the pipe assembly that connected to the tee and notice that the weight of it is causing it to kink down. Still it leaked some. Does it sound like the tee is still just worn out?
I would try a new tee...
1991 Palomino Filly PUP
motc777
Posted: 12/25/18 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
I'm tending to agree with you on this. Ordering one tonight. These are not cheap btw.
Smoke me a kipper. I'll be back for breakfast! - Ace Rimmer
motc777
Posted: 01/06/19 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
Well, the part arrived over the weekend at my office, but they are going to redeliver tomorrow.
I will hopefully have this fixed, and an update on things tomorrow. What I can tell you is that if this doesn't fix it, we are most definitely going Sharkbite.
motc777
Posted: 01/07/19 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
The part that came, oddly enough, was not the right one, the one that was suggested. The old part had prongs on the two tee connections and then the flair-it female connector. I have been looking in vain to find this.
So, having said that, can I fix this with a Sharkbite and if so, how?
mobeewan
Hampton, Va
Posted: 01/08/19 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have a picture of the old tee by itself and the fitting connecting to the tank between the tank and tee by itself?
motc777
Posted: 01/08/19 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have a picture of them separately no, but I have an update.
Basically, Flair-it no longer makes the part I need. So I took a trip to the local True Value Hardware Store, where the owner, who's family has nearly 100 years of experience, showed me the following:
And then on the other side of the tee a short piece of Pex going into the following:
Now, I had to get a new heating element because last night I fired mine up without enough water in it, but it was old anyway. I should hope to have this up and running tomorrow. Again, not using the above parts just yet, because I want to see if replacing the sanoprene seal and adding some pipe threading helped.
* This post was edited 01/09/19 01:20pm by motc777 *
Bobbo
Wherever I park
Posted: 01/08/19 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
Please resize your second image like I just did in the quote.
Bobbo, Linda and the furry kid (45 pound rescue)
drsteve
Michigan
Posted: 01/09/19 07:48am Link  |  Quote  |  Print  |  Notify Moderator
Why does this forum's software not resize pics automatically? It's not hard.
motc777
Posted: 01/09/19 11:53pm Link  |  Quote  |  Print  |  Notify Moderator
New heating element is working like a champ. While I still have a leak, the leak has literally slowed to a snails pace. Still, I am going to repair that with the valves and PEX mentioned above.
