RV.Net Open Roads Forum: Truck Campers: Time for some new 19.5 rubber...recommendations?
 > Time for some new 19.5 rubber...recommendations?
luv2skyski
Stockbridge, Georgia
Posted: 11/18/18 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
Well, it's finally time for some new tires.
I bought Vision 81's and Goodyear G647 RSS from Rickson back in 2007. I put over 63,000 miles on them. I had the usual squirmy first few hundred miles or so but other than that no problems.
FWIW: I've never had to have them balanced. (Rickson did their "Match Mounting" and used EQUAL balancing compound.)
I did some research and it looks like they still make that model tire ($420 each, including FET, with free shipping).
Doesn't seem to be any recent posts regarding tire recommendations. What brand / model has everyone been getting lately?
As always, thanks in advance.
Dave.
2004 Northern Lite 10-2000RR, 1999 F250
luv2skyski.com
Northern Lite Owners
Truck Camper Enthusiasts Map
4 out of 3 people have trouble with fractions.
fpoole
PNW and Beyond
Posted: 11/18/18 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Nice, I'm looking for new ones too.
Les Schwab, In PNW suggest some but Yikes...
Cost was some $600 x 6 = $3600... 10 ply or something like that...
So interested in seeing what is recommended...
thanks..
Frank Poole
Roam'n ROG (Retired Old Geezer/Goat)
2016 RAM 5500, C/c, 6.7 Diesel, AISIN HD 6-spd, 19.5 DRW, 72 Gal fuel, 4x4, 10ā€™ Alum FB, 440 Amps, 4.10 Axle
2016 AF 990 640-Solar/10-6v Batts
GlowStep Stow Nā€™ Go, E-Bike
RS1 Buggy
frank
Pooles website
2oldman
Ca
Posted: 11/18/18 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
More tires posts
Tires in Tow vehicles
Oregun
Oregon
Posted: 11/18/18 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
I have been happy with my Cooper Roadmaster 19.5's I got 4 of these on my SRW F350. They wander until they are broke in.
Bedlam
PNW
Posted: 11/19/18 09:52am Link  |  Quote  |  Print  |  Notify Moderator
You have already worn through your original 225/70R19.5 tires? How many miles do you have on them? I have about 38k miles on mine and carry a lot more weight than you yet think they will age out before wearing out.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
fpoole
PNW and Beyond
Posted: 11/19/18 10:58am Link  |  Quote  |  Print  |  Notify Moderator
Yah, I'm right up to 58k miles now... They're still good, but it's moving up the list...
I figure about 65k miles would be the trigger to get serious....
I checked out Schwabs, as noted... various qualities, but I'm finding I'm doing more 'Off Road', dirt/washboarded roads so it changed a little... sigh, heheh, to the more expensive ones... go figure...
parkmanaa
Houston, Tx.
Posted: 11/19/18 11:59am Link  |  Quote  |  Print  |  Notify Moderator
After using Michelins for more years than I care to remember, I wholeheartedly recommend you give them serious consideration.
I am using the 22570R19.5 in the XZZ tread design on my small motorhome. Very happy with them.
I always buy my tires from an on-line marketer and then have them mounted locally. Last tires were from SimpleTire.com. They were less than 6 mos. old when I received them.
They show 5 tread designs and load ranges (LRF and LRG). Only show price for one, the XZE in Load Range G (14 PR). $424, all inclusive including shipping. Local mounting will probably run another $25. per tire.
Makes the 6 cost about $2700.
jimh425
Western MT
Posted: 11/19/18 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
I run Bridgestone M724s on front and Hankook DH-01s on rear. The Brigestones still have great traction, but ride better than the Hankooks on the front. I'm running Fs since that is plenty capacity for me, and I only run75-80 lbs on my F450.
Puttin
Martinez, Ca
Posted: 11/19/18 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
I just bought a set(6) of Dawg Pound Urban Dawgs (H Load Rating). $1698.00 mounting and balanced. Ride as nicely as the G670's they replaced.
JimK-NY
NY
Posted: 11/19/18 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
Wow. Eleven years on tires used to haul a TC. Regardless of the mileage, I would have replaced them years ago. Since you only went 60K miles in all those years, I would buy more medium grade tires and replace them way more frequently. The usual recommendation is 7 years but with low use even that is questionable. The lower the use, the more frequently tires should be replaced. An unused tire should be replaced in about 4-5 years.
