RV.Net Open Roads Forum: Fifth-Wheels: Bike racks in the rear
 > Bike racks in the rear
Page of 5
Thermoguy
Graham, WA
Posted: 11/22/18 09:40am Link  |  Quote  |  Print  |  Notify Moderator
I have a good 2" receiver on the back of our 5th wheel. Attached to the frame not the bumper. I looked at putting a hitch on the front of the truck but found this Yakima rack designed for the back of trailers. It does not fold down for SUV's so it is solid. It also has a locking nut that I can tighten so no bouncing over bumps.
Here is a link to Amazon for the Yakima bike rack.
https://www.amazon.com/gp/product/B01N4RV9IB/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
The only problem is I can't put 4 mountain bikes on it. My sons bike does not have a straight cross bar so his takes up more space. I can easily get our 3 bikes on it and have safety straps just in case.
Camper4871
South Carolina
Posted: 11/22/18 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
I was behind a 5th wheel Monday with one of those mini golf carts on a rack.
I followed for several miles and it was very stable. I really wanted to flag him down so I could examine it!! Looked like it was mounted by way of 2 2' receivers, one close to each end and mounted to the frame. If anybody knows a model or manufacturer for such, I would love to know. The mini golf carts weigh about 300 pounds.
RVman3252
Ohio, USA
Posted: 11/27/18 10:54am Link  |  Quote  |  Print  |  Notify Moderator
I use a Swagman, 2 Bike Rack on the back of our 5th Wheel. I have a 2" Receiver on the back, and just slide the Bike Rack in. I normally put a cover over them and add ratchet straps and bungee cords to keep the air from tearing up the cover. I have been doing this for well over 20 years and have never had the 1st problem.
RVman3252
3252Px3 KZ Sportsmen Limited Triple Slide Fifth Wheel
Dodge Ram HD3500 CrewCab, Longbed 4x4 Cummins w/ PullRite Super 5th
Good Sam Life Member
irishtom29
San Antonio
Posted: 11/28/18 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
Lwiddis wrote:
Good quality bicycles are never carried on the back of an RV.
They’re not? You’re misinformed, I see it often.
rhagfo
Portland, OR
Posted: 11/28/18 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
Dave H M wrote:
IAMICHABOD wrote:
One of the things is the rocking and the damage it can do when the bike carrier is mounted in a RECEIVER .
You need a good anti rattle device so you don't get so much play in the receiver,thus magnifying the movement and doing more damage to the bike carrier.
I have tried almost every Anti Rattle device on the market, most have been no good or so complicated and cumbersome that they are useless. Including the Roadmaster type,totally useless.
Until I found the one at Hitch Rider.
Their Hitch Vice is the best and easiest one I have come across and it really works.
I have one of those to take all the slop out of the hitch for the rack. I messed around for quite some time before stumbling onto that device. It is the cat's meow.
If you buy a quality bike rack it will have a bolt rather than a pin to attach to the receiver. Our Swagman XC2 has a bolt that pulls the rack tight to the side of the receiver, with a pin to prevent it from backing out if you ignore it for years.
Swagman XC-2 bike rack
Swagman XTC-4 4 bike rack
It also amazes me that people can't grab the concept of carrying bikes on the front of a 5er attached to the pinbox. Never a worry about if they are beating themselves to death, or even back there, you have them in your view. I have a cover on ours and it stays in place with a few bungee cords.
This is our unit with bike rack on 5er and cover in place on the Oregon Coast.
RollandB
Albany, Or
Posted: 11/29/18 07:53am Link  |  Quote  |  Print  |  Notify Moderator
Russ, we joined the “bikes up front” the end of summer. Which cover are you using?
2005 Silverado 3500 Crew Cab Long Box, Duramax/Allison, B&W Companion, TST507's
2016 Artic Fox 27-5L
Puddles
Lafayette, Indiana
Posted: 12/01/18 06:42am Link  |  Quote  |  Print  |  Notify Moderator
Ditto this question... had a cover custom made... by third trip, a peddle had punched thru the cover... like hauling the bikes in that location, but lots of wind pressure up there.
HTML
hotpepperkid
Kingman AZ
Posted: 12/01/18 07:06am Link  |  Quote  |  Print  |  Notify Moderator
I did exactly that. Removed the stablelizer jacks, welded 2" receiver material to the frame. Rewelded the stablizers to the receiver stock and build a rack to fit. Carried my gen and large cooler on it for years
2019 Ford F-350 long bed SRW 4X4 6.4 PSD Grand Designs Reflection 295RL 5th wheel
IAMICHABOD
Sunny So Cal 90713
Posted: 12/01/18 08:24am Link  |  Quote  |  Print  |  Notify Moderator
I do have a quality Swagman bike rack with the bolt,no matter how tight that you get it you will still have some slop,the Hitch Vice does eliminate all movement.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
azjeffh
Full-timing the USA (formerly Chandler AZ)
Posted: 12/04/18 08:42am Link  |  Quote  |  Print  |  Notify Moderator
Have almost 3 years on the road and 15K miles with my Thule T2.
Jeff
Wonderful wife Robin
2016 F350 PSD Dually
2016 DRV 38RSSA
Page of 5
