RV.Net Open Roads Forum: Beginning RVing: how to prevent dragging?
 > how to prevent dragging?
DutchmenSport
Over There
Posted: 11/20/18 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
I never had a problem with any of my travel trailers dragging even my 35' out back. But for the 1st time in probably 15 years my Montana high country drug just a couple days ago on our trip to Louisiana. It's made me keenly aware that I need to watch not only what's happening on top for heights but also on the sides for with and also on the bottom for skidding. Welcome to the big league.
dmck413
Fluvanna Va
Posted: 11/20/18 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
I drag backing out of my driveway. I solved this by mounting steel wheels under the frame about 1 foot in from the rear of camper. They swivel and picked them up at Tractor supply. Been using them for 4 years with no trouble.
George3037
Upstate NY
Posted: 11/20/18 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
Obtain and mount some swivel skid wheels with u-bolts on the rear of the TT frame.
Another option would be to have the trailer axles mounted below the springs instead of above them therfore raising the TT frame.
Terryallan
Foothills NC
Posted: 11/20/18 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
That is how I had mine raised. It no longer drags. that raised it about 5 inches. Before it would drag on any incline.
Cost? 450 to 500 bucks
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Veebyes
Posted: 11/20/18 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
If it is a local to you station don't go there, at least not with the trailer.
Almost 200,000 miles of travel behind me & I have come across very few, mostly older, stations with potential dragging issues. More often than not those before have left their marks giving a good warning & a chance to proceed or abort using that station.
It is not a big deal really.
Now if I had a driveway that was a problem I'd be putting boards in the gutter before drilling holes & mounting wheels or skids.
2007 Alpenlite 34RLR
Wherever I happen to park
Posted: 11/20/18 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
They make what hot rodders call "Sissie wheels" that attach to the rear frame (NOT to a tin foil bumper but a solid frame part) with "D" bolts and .. Well they are solid steel rollers. Talk to your dealer.
Home is where I park it.
DarthMuffin
Driveway
Posted: 11/20/18 10:59pm Link  |  Quote  |  Print  |  Notify Moderator
Get a cardlock gas station card (Pacific Pride, etc). You don't need to be a business, just pass a credit check. They're generally set up for large vehicles, and it's sometimes handy being able to buy gas in bumshart, nebrahoma at 1am.
valhalla360
No paticular place.
Posted: 11/21/18 06:15am Link  |  Quote  |  Print  |  Notify Moderator
Keep in mind adding wheels reduces your clearance and puts stress on the corners of the frame.
Best bet is to fill up before hooking up and if you have to fill up in route, use truck stops.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
hornet28
Muskegon
Posted: 11/21/18 07:55am Link  |  Quote  |  Print  |  Notify Moderator
Choose your stations for ease of entry and egress. If you still need to use one with an steep angle approach at an angle instead of nearly straight on.
Allworth
Orlando, FL
Posted: 11/21/18 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
Not telling us where you are located or whether you are gas or diesel makes it so much easier to try to help you.
In 100,000 miles or so of towing this has happened to us only once (in New England).
Fuel without the trailer (not always possible).
Use truck lanes (mostly diesel).
Avoid stations crowded with cars even if price is more (still cheaper than frame alignment).
Stay situationally aware!
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
