RV.Net Open Roads Forum: Tech Issues: Onan 5500 flooding
 > Onan 5500 flooding
Kober
Arizona
Posted: 11/20/18 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
So my Onan 5500 generator won't start. Removed airfilter and watched fuel spitting out at me from the little hole next to the air intake. Drained the bowl, generator started, ran for 30 seconds, fuel spit back out at me and generator stopped running.
Thinking stuck float in bowl?
Maybe try and clean without removing the carburetor?
Any advice is appreciated.
2004.5 Dodge 3500 4x4 DRW CTD 600, Warn Winch etc,
2008 FUZION 362.
PATRIOT GUARD RIDER, AMERICAN LEGION RIDER
Retired 25 years US ARMY, retired 24 years business owner
eHoefler
ozark mountains
Posted: 11/21/18 05:05am Link  |  Quote  |  Print  |  Notify Moderator
Stuck float or debris blocking float. Disassemble and clean
2019 Ram Limited, 3500, Crew Cab, 1000FTPD of Torgue!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
77rollalong
Brighton Ontario
Posted: 11/21/18 05:41am Link  |  Quote  |  Print  |  Notify Moderator
disassemble and clean the float bowl and check the condition of the end of the needle the see if it is rubber tipped or not, sometimes they swell up (rubber) and may need a new needle and seat.
Kober
Arizona
Posted: 11/21/18 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Can the bowl be removed without removing the entire carburetor?
RLS7201
Posted: 11/21/18 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Yes............Remove the fastener in the center of the bowl.
Also check that plastic float for cracks. Shake it to see if there is fuel inside.
Richard
If I had a dollar for every girl that found me unattractive,
they would eventually, find me attractive.
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
Kober
Arizona
Posted: 11/21/18 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Richard
Good call. My float is full of fuel but I can not find a crack or hole. Now what?
msmith1.wa
Tacoma, WA
Posted: 11/21/18 11:25pm Link  |  Quote  |  Print  |  Notify Moderator
Most likely you will have to replace the whole carb, because the pin that holds the float is pressed in and not easily removed.
2003 Silverado 2500HD 4x4 8.1l
2016 Evergreen Amped 28FS
Kober
Arizona
Posted: 11/22/18 08:04am Link  |  Quote  |  Print  |  Notify Moderator
Actually I was able to get it out without too much trouble.
RLS7201
Posted: 11/22/18 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Richard
There are float/needle kits available. Not having the model # makes it impossible to guide you to the exact float but the float in this link may work.
Richard
lamopar
Oregon
Posted: 11/22/18 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
So our Onan was doing the same thing. I pulled and cleaned it and fought it for two years. Finally I purchased a carb off Ebay and replaced the factory unit. Started immediately and has worked ever since. I changed to only adding non-ethanol fuel to the generator tank and my fuel station tank. Same thing with my sons Can-Am DS90X and it has worked perfect ever since. The generator carb was replaced two years ago and will start and run great every time I try it now.
That was my route and it worked. I know others have had luck cleaning and replacing parts but this was fast and worked perfect.
