RV.Net Open Roads Forum: Tech Issues: Onan 5500 flooding
 > Onan 5500 flooding
Kober
Arizona
Posted: 11/22/18 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
RLS7201 wrote:
Kober wrote:
RLS7201 wrote:
Kober wrote:
Can the bowl be removed without removing the entire carburetor?
Yes............Remove the fastener in the center of the bowl.
Also check that plastic float for cracks. Shake it to see if there is fuel inside.
Richard
Good call. My float is full of fuel but I can not find a crack or hole. Now what?
There are float/needle kits available. Not having the model # makes it impossible to guide you to the exact float but the float in this link may work.
Richard
Thank you for the link.
2004.5 Dodge 3500 4x4 DRW CTD 600, Warn Winch etc,
2008 FUZION 362.
PATRIOT GUARD RIDER, AMERICAN LEGION RIDER
Retired 25 years US ARMY, retired 24 years business owner
Kober
Arizona
Posted: 11/22/18 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
I removed and drained the float, found the leak and sealed it. It started right up but only time will tell if I was successful in sealing it completely.
Thanks everyone for your input.
bounder39zman
SC
Posted: 11/24/18 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
good job on that repair. This is a common problem with these carbs.
As it is an "emissions" part, Onan does not offer any repair parts except the choke heater and vacuum valve (choke pull-off).
Fortunately, being in the"business", I have about a hundred of these carbs (used ) laying around, and can usually find a float to repair an otherwise good carb. that is no longer under warranty.
