RV.Net Open Roads Forum: Tech Issues: 110 volt switch on hot water heater.
 > 110 volt switch on hot water heater.
Jay Pat
Round Rock, TX
Posted: 11/28/18 10:12am Link  |  Quote  |  Print  |  Notify Moderator
I turned on the 110v element of the hot water heater. The one mounted outside on the hot water heater.
It has the anode rod.
Yesterday, I tried to turn the switch off and it will not move. It is stuck in the on position.
I have pressed a lot harder than normal. It won't move from the on position.
Is this easy to replace?
Pop, the switch out?
Thoughts?
Pat
I used the breaker to turn the hot water heater off.
2010 Ford F-350 SRW
2011 Keystone, Sprinter 310
2oldman
Salton Sea
Posted: 11/28/18 10:16am Link  |  Quote  |  Print  |  Notify Moderator
Those water heater switches sometimes need wd-40. I gave up on mine and use the breaker. My WH is hardly ever used on 120 due to the air con usually being on, which puts a heck of a strain (and heat) on my connections.
* This post was edited 11/28/18 10:38am by 2oldman *
Dick_B
Palos Heights, IL USA
Posted: 11/28/18 10:35am Link  |  Quote  |  Print  |  Notify Moderator
It wasn't easy to replace mine which had fused due to the high current draw of the water and the cheap construction of the switch. I replaced it and now leave it on all the time.
We have another on-off switch on the kitchen wall which we use and leave the heater switch in the on position. Lately we have been using just the propane to save wear and tear on the switch which would normally be turned on/off several times each day.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
donn0128
Pronounced Ore-gun
Posted: 11/28/18 11:05am Link  |  Quote  |  Print  |  Notify Moderator
Those switches are notorious for failing. I learned early on to turn the breaker off and leave that cheap crappy switch alone.
Don,Lorri,and Charlie Bear 2016
8 years OSP Camp Host
The Other Dallas
BB_TX
McKinney, Texas
Posted: 11/28/18 11:27am Link  |  Quote  |  Print  |  Notify Moderator
Yes, they just pop out.
water heater switch
SoundGuy
S Ontario
Posted: 11/28/18 11:31am Link  |  Quote  |  Print  |  Notify Moderator
Our K-Z Spree had a Suburban SW6DE water heater and because the electric heating element switch was located on the unit itself we rarely used that function. Finally I got tired of the silliness of having to go outside to turn the switch on/off, simply left it on, and wired this paddle switch in line with the 120 vac feeding the WH element. It has a light to indicate when power is on and is mounted in a convenient to reach location. In the OP's situation, assuming the WH switch is still passing power, I'd just leave it as is and install a switch inside the camper, just as I did in my Spree.
2014 Coachmen Freedom Express 192RBS * 2003 Fleetwood Yuma
2008 K-Z Spree 240BH-LX * 2007 TrailCruiser C21RBH
2000 Fleetwood Santa Fe * 1998 Jayco 10UD * 1969 Coleman CT380
bob213
Fresno, CA
Posted: 11/28/18 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
I like SoundGuy's solution. A circuit breaker is not intended to be an on/off switch unless designated as such. I would suggest this reroute, replace the cheap toggle switch or carry an extra circuit breaker if you are going to use it as an on/off switch.
bpounds
Senile, er I mean
Posted: 11/28/18 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Just an unlikely possibility here, but my switch has a little wire clip that locks it into position. Are you sure that clip isn't in place?
Come to think on it more, I think it can only be clipped in the off position. I assume to prevent it being turned on while the WH is empty.
Oh well, just a thought. We don't use ours on electric, ever, so it stays clipped off at all times.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
dons2346
Sioux Falls, SD, formerly of So. CA
Posted: 11/28/18 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
Been there done that.
You can open up the box it is in and cut the wires to the switch and splice them together. Then use the breaker on the 110 volt panel to turn it off and on. It is cheap switch to begin with
DutchmenSport
Over There
Posted: 11/28/18 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting topic. Three travel trailers and now my first 5er, all had gas-electric water heaters. Never had any problems with the switch on the tank. But, 90% of the time, we use gas too, that save power draw on only 30 amp availability.
Actually, I've never, ever thought about flipping the breaker switch. All mine have had the double switch; one on the tank the other inside the camper on the wall. And only 1, our first one, the Dutchmen Sport had the cotter pin in the switch on the tank. All the others have had solid switches with no hole for a cotter pin. I liked the cotter pin. It was a comfort knowing the switch was in the off position and secured down.
