RV.Net Open Roads Forum: Tech Issues: 110 volt switch on hot water heater.
 > 110 volt switch on hot water heater.
old guy
Oregon (pronounced Or e gun)
Posted: 11/28/18 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
I pop mine out with my pocket knife. it is one of the easier repairs on a TT. you can buy them on amazon or a rv dealership. before I replaced mine I would just use a screw driver or an wrench and basically hit it on or off. then I got smart in my old age and got to thinking that can't be too good for the switch so I buy two or three of them to replace them when they start to stick
Jay Pat
Round Rock, TX
Posted: 11/29/18 05:29am Link  |  Quote  |  Print  |  Notify Moderator
After looking at the link BB_TX supplied, I’m going to go for replacement.
I do like the idea of the switch in the rv. Will have to check that out.
Thanks everyone for their thoughts and suggestions!!
Pat
2010 Ford F-350 SRW
2011 Keystone, Sprinter 310
beachcomber_1
Alton, Illinois
Posted: 12/05/18 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting, my water heater switch carries a load only to a relay. Relay carries the lod for heating element. Switch never has heavy load across terminals, simple and easy fix.
Jay Pat
Round Rock, TX
Posted: 01/11/19 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
Follow up post!
I pulled/pried the stuck switch out using a tool with a 90 degree hook on the end.
The switch cleared the housing by about 3/8". There was no more slack in the wires. Just would not come out any farther.
Impossible for me to unplug and keep connectors from falling in the hole.
I had a rv mechanic doing other stuff and had him look at it.
He took the switch with the short wires and lifted up and out. More wire came out the hole.
The switch had 90 degree connectors and I was hitting the connector/wires, pointing down inside the opening.
All I had to do was lift up on the switch and more wire would have come out. Nuts!
He lengthen the wires to reach inside the rv to the water heater cover.
I'm currently looking for a indicator light switch to install on the cover.
This will probably be my last post on this subject.
It will be nice to have an indoor 110 volt switch for the hot water heater.
Thanks, for everyone's input!!!
Pat
Retired JSO
Northeast Florida
Posted: 01/11/19 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
Amazon has the switches based on Model number. Go get a light and look up inside the switch cavern. There is a twist on the wires that will keep it from pulling out. I got mine out far enough to use needle nose pliers to remove the wires from the old switch and onto the new.
wopachop
lb
Posted: 01/18/19 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
Do people who full time in RVs keep their water heater turned on all day on 120v?
mchero
Henniker, NH
Posted: 01/18/19 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
We leave our HWH on electric 24/7.
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
Dusty R
Charlotte Michigan 48813
Posted: 01/18/19 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
HWH Hot Water Heater. How do you heat hot water?
Dave H M
IL
Posted: 01/18/19 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Ummmm, Dusty, do you know how many comedians out there that are looking for a job? [emoticon]
And Jay Pat, I need to get off my butt and transfer mine inside also.
Thanks for the feed back.
wopachop
lb
Posted: 01/19/19 11:00am Link  |  Quote  |  Print  |  Notify Moderator
Ive heard this joke for years but its true at times. It is a hot water heater.
I hear it cycle almost hourly in my trailer. There is hot water in the tank. Then the heater (gas or electric) turns on and heats the hot water even hotter. So yes, its in fact a hot water heater. This happens even if no cold water is introduced into the system.
Mine electric element seems to cycle on way to often. Same problem as others my switch got stuck.
I think my element burnt out the other day. Trailer smelled like burning electrical and water isnt hot. Heard its an easy repair but havnt looked into it yet.
Do they normally pull 11amps? Thats what started the problem. Turned off power and hooked up an amp meter because i was curious. Flipped the water heater back on and read 11amp on the meter. Went inside the trailer 30 mins later and it smelled bad.
