RV.Net Open Roads Forum: Tech Issues: Honda EU2000i? leaks fuel after cleaning
 > Honda EU2000i? leaks fuel after cleaning
kmb1966
Lake Charles
Posted: 11/30/18 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
My Honda EU2000i was surging, so I ordered new gasket set, took the carburetor apart, soaked it in carburetor cleaner overnight, blew it out with compressed air, put it all back together. Now it starts right up and runs decent (not surging) but it is dripping fuel out where the breather intake meets up with the carb (choke area). So I took it back apart and re-checked it all thinking I had put the float on wrong or something, but it all appears to be right, but something is not right because it is leaking fuel. Thinking of cutting my losses and just buy a new carburetor.
MFL
Midwest
Posted: 11/30/18 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
Any chance you could call Honda technical assistance, and get their opinion/advice?
Jerry
kmb1966
Lake Charles
Posted: 11/30/18 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
Jerry
No, I didn't know there was a help line.
I did go visit the Honda dealer when buying the gasket set and they basically said "BRING IT IN, WE ONLY CHARGE $125 per HOUR"
I don't mind paying $125 per hour, but a whole new carburetor is about $125.
romore
Okanagan valley British Columbia
Posted: 11/30/18 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
Remove the carb and invert it after draining the gas. Suck on the inlet nipple then stick your tongue over it, if it doesn't hold the needle is not sealing. No, it doesn't taste good.
2oldman
Ca
Posted: 12/01/18 10:53am Link  |  Quote  |  Print  |  Notify Moderator
Tried youtube?
wif
The North Atlantic
Posted: 12/02/18 10:08am Link  |  Quote  |  Print  |  Notify Moderator
Check to make sure you haven't bent the float bowl. If it's not perfectly centered when you reinstall the center bolt, it'll bend up in the center and cause the outer edge not to contact the gasket in the carb body. If this is the problem , just remove the bowl and tap the center flat again from the inside. As a Honda powersports tech, I see this ALL the time from customers trying their own carb work.
Doug & Trish
Scooter the camping cat
2011 Ford F150 5.0 SCAB
2009 R-Vision TS21RBH
Honda EU2000i
kmb1966
Lake Charles
Posted: 12/02/18 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
Tried youtube?
Yes. Used a variety of youtube videos to figure out HOW to disassemble and clean the carburetor.
Kober
Arizona
Posted: 12/09/18 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like float is sticking.
2004.5 Dodge 3500 4x4 DRW CTD 600, Warn Winch etc,
2008 FUZION 362.
PATRIOT GUARD RIDER, AMERICAN LEGION RIDER
Retired 25 years US ARMY, retired 24 years business owner
MFL
Midwest
Posted: 12/11/18 10:31am Link  |  Quote  |  Print  |  Notify Moderator
kmb1966 wrote:
Jerry
Honda Customer Support: 800-286-3076
