RV.Net Open Roads Forum: Travel Trailers: Toilet pipe
 > Toilet pipe
SDM
KANSAS CITY MO.
Posted: 12/02/18 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
My son-in-law has a Salem trailer. The 3"pipe from toilet to tank looks like it goes to about 2" from bottom on tank. Therefore the toilet solids will not flow out in the tank. I think the pipe needs to be shortened. My question is the pipe gluedto a fitting in the tank, or does it slide in a rubber type grommet?
agwill
enosburg falls, vt
Posted: 12/03/18 05:07am Link  |  Quote  |  Print  |  Notify Moderator
All are made that way. Sh.t floats and most solids are breaking down. Dump when tank is full and use lots of water when flushing.
al
drsteve
Michigan
Posted: 12/03/18 08:31am Link  |  Quote  |  Print  |  Notify Moderator
2" from the bottom of the tank? I've never seen one like that. Sounds like a problem to me.
1991 Palomino Filly PUP
opnspaces
San Diego Ca
Posted: 12/03/18 08:43am Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately trailers are all different and the pipe could be glued into a collar or only a slip fit into a bushing. You're probably going to have to pull the toilet and unscrew the flange to figure out which you have. 2 inches seems extreme, but if the solids are staying in the pipe then I would bet you have a slip fit that can be pulled up higher and trimmed off.
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
garyemunson
Reno, Nevada
Posted: 12/03/18 09:24am Link  |  Quote  |  Print  |  Notify Moderator
The RVs I've had have always been like that. I think the idea is that helps the extra water you SHOULD be using disperse the solids when you flush instead of just washing over the pile to the sides of the tank. Should not be a problem if you always dump an extra bowl or two of water after a flush. There is probably a dried up partial "poop pyramid" stuck to the bottom of the tank making for a difficult flush.
badsix
north bend or.
Posted: 12/03/18 11:14am Link  |  Quote  |  Print  |  Notify Moderator
2" is just looking for a place to plug up. mine just dumps in the top or near the top if you have some water in the tank you have no problems.
Jay D.
beemerphile1
Ohio
Posted: 12/03/18 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
That 2" gap is way too little.
The pipe may be glued and may be inserted into a rubber bushing. In my RV it is glued. You will need to remove the toilet and take the screws from the flange to find out.
2018 Keystone Cougar 26RBS
Farmboy666
Pisgah Forest, NC
Posted: 12/04/18 08:04am Link  |  Quote  |  Print  |  Notify Moderator
Does it just look like it or is it actually 2" from the bottom?
bpounds
Senile, er I mean
Posted: 12/04/18 10:23am Link  |  Quote  |  Print  |  Notify Moderator
2" from the BOTTOM is definitely not right. I can't believe anyone would think that it is normal. If it really is like that, you are going to have to fix it. Is this a new trailer? That would be a warranty item. If an old trailer, pipe might have slid down. Doubtful that anyone would live with it like that for long term ownership, but then some people never use their toilet, so anything is possible.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Timtation
Mid-West
Posted: 12/07/18 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
Dremel tool with the flexible extens├Čon, use the circle saw blade and cut the pipe an inch or two higher and repeat until it extends about 1/4 of the depth of the tank. By cutting in small increments there is a good chance of flushing them without blocking the discharge pipe. FWIW
 > Toilet pipe
