RV.Net Open Roads Forum: Class A Motorhomes: Transynd vs Dexron VI
 > Transynd vs Dexron VI
Coach Cleats
Watertown, Ct
Posted: 12/03/18 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Can Dexron VI be used to replace Transynd on my 2004 Allison 3000 transmission for a fluid and filter change?
2004 Safari Cheetah 36 PDD, 03 Wrangler Sahara Toad W/Buddy Brake.
Denise and Bob 70 Years as Teachers!
Kodi D'dog'.
About to play as long as we worked.
Senior Softball! What a blast. Nothing is routine!
wolfe10
Posted: 12/03/18 08:57am Link  |  Quote  |  Print  |  Notify Moderator
That is a question I would ask Allison. Better than our opinion.
Suspect it can be used, but do not know how it affects recommended change intervals.
I have always just bought a 5 gallon PAIL of Transynd and the Allison filter kit from our local Allison Dealer. The pail leaves you with one quart left over and is less $$ than buying individual gallons/quarts.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
rgatijnet1
Posted: 12/03/18 10:10am Link  |  Quote  |  Print  |  Notify Moderator
Allison ONLY recommends transmission fluid that is TES-295 approved. Several manufacturers meet this spec. I would not use any fluid that does not say that it meets the Allison TES-295 specifications. The older transmissions did come with a non-295 Fluid, probably Dex III in your case, but why go with any inferior fluid when Allison now recommends a fluid that meets TES-295 in their older transmissions. You do not have to buy Allison fluid if you don't want to give them the money but I would definitely recommend buying the newer spec fluid from someone, anyone, instead of using an older fluid. Saving a few bucks on a transmission that can cost $5000+ to repair just doesn't make sense. BP, Castrol, and others make the TES-295 fluid that you need. Try to find one on sale and use the right, most recent fluid, instead of using a fluid that Allison abandoned many years ago for their transmissions.
RCMAN46
NorthWest
Posted: 12/03/18 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
I am almost sure your 2004 Allison has seals that are not compatible with Dextron VI but they are compatible with Transynd.
Dextron VI post #63
jorbill2or
Oregon
Posted: 12/03/18 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
What makes you think your transynd is bad ? I’d have it tested and change the filters .. in mh use I doubt it will wear out. Your call but it’s expensive and if it test ok I would use it , some won’t and are only time centered
I was told they are comparable but must be changed if used frequently.
Bill
eDUBz
Oxnard
Posted: 12/03/18 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
Stick with what Allison recommends, the transynd. When I bought my LBZ first thing I did was change to transynd. They recommend to change ever 100k so it’s not much as far as cost goes.
LBZ - Stealth - RZR - Honda - SUPsurf - Fish - Kayak
RCMAN46
NorthWest
Posted: 12/03/18 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
Dextron VI post #63
I may be wrong as I did not notice it was an Allison 3000 but what I have indicated is true for a 2004 Allison 1000.
wolfe10
Posted: 12/03/18 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
If the question is "should I change the fluid":
How many years old/how many miles on it?
Charlie D.
E. Texas-Orange
Posted: 12/03/18 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
The Diesel Supplement manual for the 2018 D/A recommends Dexron VI above temps of -40 F. Below that it specifies TES 295. That holds true for 2013 and up model years
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
rgatijnet1
Posted: 12/03/18 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
So basically anyone that has an Allison transmission anywhere other than the frozen arctic should not use Transynd TES-295 rated fluid, since most of the lower 48 has temps above -40 F. Only use TES-295 for temps less than -40 F. I think you need to reread your source. [emoticon]
