RV.Net Open Roads Forum: Class A Motorhomes: 1990 gulf stream heads
 > 1990 gulf stream heads
atvbob
So. Ogden, UT
Posted: 12/03/18 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
I'd like to know if exhaust ports on this carberated 460 has rectangle or oval ports.
I saw a response posted by Hooligan 4/2013 that he had the same chassis, don't know if he's still on forum, hopefully he remembers.
Thanks Bob C.
Wire Man
Wadsworth, Ohio
Posted: 12/03/18 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
Odd that a 1990 does not have EFI, I think ford switched to all EFI by 1988
I am thinking if it is an original carbureted engine it should be oval port.
Barney & Penny with our puppies Lucy & Ricky
2008 Fleetwood Discovery
NHRA Drag racing is our habit ">
Good Sams, FMCA, Cummins Power Club, Coach-Net
atvbob
So. Ogden, UT
Posted: 12/03/18 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
That's what my research found to, but they used carbs, I think, on m/h until about 1990 or 1991.
Mine's definitely 1990.
ScottG
Bothell Wa.
Posted: 12/03/18 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
The 460 went to EFI in 1986. 1990 should have throttle body injection (looks like a carb) unless someone did something silly to it or it's not the orig eng.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Bruce Brown
Northern NY
Posted: 12/04/18 03:45am Link  |  Quote  |  Print  |  Notify Moderator
Being a 1990 MH doesn't mean it's a 1990 chassis. It could very easily be a 1988 or 1989 vintage chassis.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
ScottG
Bothell Wa.
Posted: 12/04/18 09:28am Link  |  Quote  |  Print  |  Notify Moderator
Would still be EFI.
RLS7201
Posted: 12/04/18 10:54am Link  |  Quote  |  Print  |  Notify Moderator
The carbureted cylinder heads are slightly rectangle where the EFI heads have a rounder port.
First Ford F53 was built in 1988 with EFI 460. Which was the first year of EFI on the 460.
But Oshkosh chassis continued to purchase carbureted 460 from Ford up to and including 1990. So if you have a 1989 or 1990 carbureted 460, class A MH, it has an Oshkosh chassis.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
atvbob
So. Ogden, UT
Posted: 12/04/18 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Richard (RLS7201) that's what I was looking for.
Bob C.
atsrmf
Indio
Posted: 12/07/18 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
My 1986 has oval ports, carbureted.
