RV.Net Open Roads Forum: Class A Motorhomes: Battery Storage
mikemc53
Northern Michigan
Posted: 12/05/18 05:45am Link  |  Quote  |  Print  |  Notify Moderator
I know this has been asked a lot but I am going to be storing my 2004 HR Vacationer for the first time since I purchased it this summer. Tanks and such I am fairly comfortable with but what about batteries? Should the battery disconnects be turned to "off"? I will be able to get to it every couple of weeks to run it and keep the chassis batteries going but not sure of what is best for the house batteries? It will be in central Florida so weather will be less an issue than had I stayed home in Michigan.
Thoughts?
2004 Holiday Rambler Vacationer 37PCT
10forty2
North Carolina
Posted: 12/05/18 06:15am Link  |  Quote  |  Print  |  Notify Moderator
Turn the battery switches off and let it be. If you have the option, consider a trickle charger each for house and chassis batteries. Starting the engine and letting it idle may actually do more harm that good if you don't run the engine long enough/hard enough to bring it up to operating temp. If you plan to crank it while it's in storage, take it for a spin....say 30 miles or so to make sure that the engine/transmission warm up enough to boil off any condensation that builds up while sitting in storage. If not, then you're essentially circulating water throughout the engine.
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
Wherever I happen to park
Posted: 12/05/18 06:40am Link  |  Quote  |  Print  |  Notify Moderator
If no shore power turn off or better yet physically disconnect batteries (lift negative lead(s) off terminal(s) (note a pair of GC-2 6 volt in series is ONE 12 volt battery so you lift only the most negative lead).
If you have shore power leave plugged in, hooked up and turned on.
Home is where I park it.
Sam Spade
North Central Florida
Posted: 12/05/18 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Once a month is plenty. Be sure to run it long enough to get the temp gauge up to where it normally runs.
And I think you will find that the house batteries charge when the engine runs too.
IF....you have access to shore power, it is best to get a couple of smart battery maintainers (tenders) NOT TRICKLE CHARGERS, hook one to each battery and leave it alone. Yes, do NOT start it; not necessary.
Letting your built-in charger/converter handle the task long term is not a good idea in general because many will "float" the batteries too high for long term storage.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
San Simeon area, California
Posted: 12/05/18 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Winter in central Florida is ideal for a solar trickle charger system. Works great for me in SoCal.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
pianotuna
Regina, SK, Canada
Posted: 12/05/18 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
actually batteries will self discharge faster in Florida than in the great frozen north. Do use the disconnect switches.
Regards, Don
