RV.Net Open Roads Forum: Class A Motorhomes: generator usage
 > generator usage
papagramx4
South western Pennsylvania
Posted: 12/05/18 05:56am Link  |  Quote  |  Print  |  Notify Moderator
We are the 2nd owners of a 2005 Class A Winnebago motorhome. It has an ONAN Marquise Gold 5500 generator. Where on the generator do I find the hours of usage.
NOTE: Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
    "Forum Posting Help and Support is reserved for questions on how to post in the forums, signature and photo testing, reporting website or member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, create future threads in the RV FORUM which corresponds to the subject of your topic. Thank-you!"
* This post was edited 12/05/18 03:20pm by an administrator/moderator *
zigzagrv
Nazareth, PA
Posted: 12/05/18 07:06am Link  |  Quote  |  Print  |  Notify Moderator
Not familiar with your particular motorhome, but the generator hour meter is usually mounted on the dash of the motorhome.
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
Master Tow dolly
Toyota RAV4
1995brave
San Antonio, TX
Posted: 12/05/18 07:14am Link  |  Quote  |  Print  |  Notify Moderator
Check the vent over the stove. Should also be another stop/start switch there for the generator.
KD4UPL
Swoope, VA
Most of the Onan installations I've seen have a rocker switch on a panel inside that starts and stops the generator. Usually, right beside the switch is an hour meter. The meter only displays the hours if the generator is running. Otherwise it's blank.
papagramx4
Posted: 12/05/18 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
FOUND IT !!! It was inside on the wall where the power & tank level panels are. We are pleasantly surprised to find that this generator has just 67.9 hours running time. We just did a full service maintenance on it, and it's purring like a little kitten. Thank you folks.
gbopp
The Keystone State
Posted: 12/05/18 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
67.9 hours is not much time for a 2005 (assuming it's the original generator). I run my generator every 4-6 weeks under a load.
Some may disagree about excercising a generator. I think it's a good idea.
camperdave
northern, California
Posted: 12/05/18 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
My 2005 Onan only had 50 hours on it when I bought the RV this summer. I was concerned, however it started up and ran fine. I've put quite a few hours on it since then and it seems fine. I know the obvious of rotted lines and clogged carbs, are there other issues with low hours?
2004 Fleetwood Tioga 29v
1492
Arlington, VA
Posted: 12/06/18 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Posting Help and Support
D.E.Bishop
Eagle Rock, CA
Posted: 12/06/18 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
I am not a specialist in Onan generators but they do recommend that their generators be run on half load for 2 hours every month which is at least 300 hours for your rig. If you do not have the Owners manual for your you can download it from winnebagoind.com. The Onan manual can also be downloaded but from a Google search or from Onan.
These are things you should have in you rig.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
95 Suzuki Sidekick 4X4
Stowmaster 5000
tragusa3
upstate south carolina
Posted: 12/07/18 04:36am Link  |  Quote  |  Print  |  Notify Moderator
I just purchased a 2011 that had 39 hours on the generator. I have cautiously optimistic. After putting about 15 hours of my own on it, it has never acted up. Crossing fingers.
New to us 2011 Tiffin Allegro Open Road 34TGA
Join us on the road at Rolling Ragu on YouTube!
 > generator usage
