RV.Net Open Roads Forum: Class A Motorhomes: Air Tabs?
 > Air Tabs?
down home
south
Posted: 12/05/18 10:12am Link  |  Quote  |  Print  |  Notify Moderator
I saw part of a program about Semi Driver life stiles.
One of the Advertisers was Air Tab.
The subject comes up infrequently but nothing decisively or ancedotaly has determined it a great idea. I understand the physics and aerodynamics and practicality if the design is sufficient.
Anyone use them here o know of something about them?
bob213
Fresno, CA
Posted: 12/05/18 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Debate has gone on for years. I do believe they help to keep the rear of your unit clean but if they were truly economically worthwhile we would see them on every semi out there. They travel far more miles than the average RVer. JMO
schlep1967
Harrisburg, PA
Posted: 12/05/18 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Yep, it has been debated on here before. Pretty much it comes down to the number of miles you need travel to get your money back. Very few RV'ers travel enough miles.
As to why you don't see them on semi's, there are other ways to make bigger gains like the fold out tailwind additions and the skirting you are now seeing under the sides of the trailers.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
IAMICHABOD
Sunny So Cal
Posted: 12/05/18 10:56am Link  |  Quote  |  Print  |  Notify Moderator
My RV handled very well but cross winds and passing trucks upset it quite a bit,after installing Air Tabs,cross winds and trucks are no longer a problem as it once was.
They also keep the rear of the RV cleaner,as to the help in MPG I saw very little difference.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
rgatijnet1
Posted: 12/05/18 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
My experience as well, with two different motor homes. I didn't notice any improvement in mileage but they did improve the handling in crosswinds and since I traveled a lot in the Great Plains, where wind is always an issue, I wouldn't be without my AirTabs. Basically since they cost less than a tank of gas, the improvement in handling at highway speeds, is enough for me.
mike brez
milford ct
Posted: 12/05/18 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
If I had a two gallon tank I might give them a try. [emoticon]
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
rgatijnet1
Posted: 12/05/18 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
One thing about the AirTabs topic on this forum....it always gets reviews and opinions from "experts" that have never used them. [emoticon]
SidecarFlip
SE Michigan
Posted: 12/05/18 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
I have. I had them on the cab of my Western Star conventional (before I retired) and they did help keep the trailer clean down the sides. I never realized any better fuel mileage however What improved the fuel mileage was the sleeper mounted wing (airfoil) and the nose cone on the front of the trailer. If I had, had a high sleeper I wouldn't have needed either but I had a flat top double bunk.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
pianotuna
Regina, SK, Canada
Posted: 12/05/18 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
My air tabs lowered the noise level in the cab of my class C. I do get better mileage--but only when there is a large tail wind. Handling was not bad before--and slightly better after (big truck opposite direction).
Regards, Don
mike brez
milford ct
Posted: 12/05/18 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have to hit my thumb with a hammer to know its going to hurt. [emoticon]
They look good too
* This post was last edited 12/05/18 08:34pm by mike brez *   View edit history
 > Air Tabs?
