RV.Net Open Roads Forum: Is it cheaper to heat my RV on propane or electric?
 > Is it cheaper to heat my RV on propane or electric?
Sea Six
Posted: 12/06/18 02:30am Link  |  Quote  |  Print  |  Notify Moderator
I'm paying for both the propane and electricity.
43' fifth wheel with four slides- around 400 sf or so. 2013 Dutchmen. Winters here in NW FL are mild. We get 40-50° temperatures at night typically. Occasionally it will get into the 30's and we will have a few days of subfreezing weather per year.
I have a heat pump in the main ac but the reversing valve has failed so it's just an ac for now.
I have two 1500W electric fireplaces and they seem to do a good job of keeping the place warm enough for me and my Golden Retreiver.
But would I save money if I use the propane furnace instead?
HadEnough
Traveling. Always.
Posted: 12/06/18 03:38am Link  |  Quote  |  Print  |  Notify Moderator
Propane is cheaper.
valhalla360
No paticular place.
Posted: 12/06/18 03:57am Link  |  Quote  |  Print  |  Notify Moderator
If you pay per KWH, propane is cheaper.
If electric is included in the sit, electric is cheaper.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 12/06/18 04:04am Link  |  Quote  |  Print  |  Notify Moderator
Prove it to yourself.
Even if electricity was dirt cheap at ten cents a kilowatt hour just your two heaters would mean thirty cents per hour -- ten hours three dollars -- ninety dollars per month.
But ten cents per kWh is like the days of the buck and a quarter breakfast special and grocery store Ten For A Dollar chicken pot pies.
The actual cost is more like three times that. I remember my aunt in Seattle hooting "We pay three cents per kWh for power!" That was sixty years ago.
Your propane furnace probably has 500% more heating power available.
DustyR
Posted: 12/06/18 04:28am Link  |  Quote  |  Print  |  Notify Moderator
I paid apx .21 per KWH in the RGV and heated with electric or propane. Mild winters cost per month was pretty much equal electric or propane. Apx $48 per month.
Coachmen Denali 270FK 32 Ft.
Tow Vehicle: 2008 Silverado 2500 HD
Duramax, Allison Transmission,
EFI by Kory, 4" Exhaust w/muffler turbo back
guidry
Texas Cajun
Posted: 12/06/18 06:01am Link  |  Quote  |  Print  |  Notify Moderator
Propane is probably cheaper but you’d have to refill whereas electric you don’t.
RJsfishin
Winston Or.
Posted: 12/06/18 06:29am Link  |  Quote  |  Print  |  Notify Moderator
Don't know how propane could be cheaper when 25% of the heat is going out the exhaust. But nothing is cheaper than my 2 Olycats on propane
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
TenOC
On the road -- Full time
Posted: 12/06/18 07:15am Link  |  Quote  |  Print  |  Notify Moderator
I am not sure that propane is cheaper because the RV furnace is not very efficient. If you have a unvented Mr Heater propane heater that is APPROVED for use in a close RV or other type catalytic heater. That is no problem with CO, the propane is cheaper. However, with an unvented heater water vapor can be a problem.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
prichardson
Lafayette, La
Posted: 12/06/18 07:46am Link  |  Quote  |  Print  |  Notify Moderator
It really depends on the cost of each in your area. The combined draw of the space heaters is 3 KW per hour of running. Your furnace will draw its rated BTU per hour of running. A gallon of propane contains apx. 90,000 BTU.
larry cad
ohio
Posted: 12/06/18 07:51am Link  |  Quote  |  Print  |  Notify Moderator
Cost difference is small, but convenience factor makes a difference. I use both, but because of convenience, I use electric more during times when it is above freezing. However, when the temp goes down below freezing, I use propane more in order to keep the basement warm, to prevent pipes there from freezing. Electric heaters don't heat the basement.
By using a combination of both, it makes my propane last longer.
Our Travel Blog
