RV.Net Open Roads Forum: Tech Issues: New Meter on order
 > New Meter on order
Page of 8
MrWizard
Traveling
Posted: 12/06/18 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
wireless power meter
Volts , Amps, KwHr, AmpHr, capacity, SOC, etc...
sender and hall effect coil go at battery
display goes where-ever (as long as in signal range)
No pulling wires between the (2) pieces
going to mount sender at the battery (of course)
going to put display over the fridge where the fuse box and breakers are
the furnace is under the fridge, and no easy way to pull wire inside from the battery in basement or the OEM house mount up front behind the grill
converter is in basement, with my add-on 4D agm
meter should arrive middle next week
$40 on ebay
I went looking after remembering somebody (Mexi?) had posted a link many months back
Radiate The Happy
1997 F53 Bounder 36s
Alfred622
Rochester, MN
Posted: 12/06/18 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
After you get it, and figure out how to install it, could you test it out and post the results here?
Alfred
2005 Sightseer with Workhorse, ReadyBrute Elite towing 2003 Honda CRV
Map below shows states where we actually camped.....
agesilaus
North Florida
Posted: 12/06/18 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto on that
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
RLS7201
Posted: 12/06/18 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
The link you posted shows the sender and meter are connected by USB cable, not wireless. Can you show us the link to what you purchased, that is wireless?
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
agesilaus
North Florida
Posted: 12/06/18 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
Richard
If you read the description it does say 'wireless' and describes the 'transformer' as a hall effect device.
rk911
Wheaton IL
Posted: 12/06/18 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
agesilaus wrote:
Richard
is the USB cable then an alternative means of connecting the transformer to the meter?
'73,
rich, n9dko
Remember...if you don’t know where you’re going you're bound to end up somewhere else.
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
agesilaus
North Florida
Posted: 12/06/18 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
Could be I suppose the transformer is wired to the sending unit I suppose.
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 12/06/18 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Yep the sending unit has it's own power supply. Try extending the receiver wire to around 40" then changing orientation.
MrWizard
Traveling
Posted: 12/06/18 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
there are (3) electronic pieces , be sides the various wires
the 'Hall effect sensor' (not a transformer), yes it connects to the data sending unit
the 'data module/wireless sender which can power the display'
the display unit which can be used wireless and powered separately from the data sender
this one can be powered by 6-60vdc
can measure 0-120vdc, and 100amp
think of the display as a combination remote display and keyboard
think of the sender as the data accumulation module and remote connection to the display
the hall effect device is the current flow sensor
voltage measurement is taken by the data unit from its power input line
there are units that measure 200, 300, 500 amps
i will follow after it is installed
MEXICOWANDERER
Posted: 12/06/18 10:28pm Link  |  Quote  |  Print  |  Notify Moderator
Jeeze I guess they're weren't joking when they said "special introductory price" of $24.99
Page of 8
