RV.Net Open Roads Forum: What Brand Is The Longest Lived Serpentine Drive Belt?
 > What Brand Is The Longest Lived Serpentine Drive Belt?
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 12/08/18 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
Even if the correct size existed down here, I would have to settle for "Jolly Dragon" or some such from Happy Commune People's Factory No 39
Car has a nasty habit of immediately throwing the drive belt when it goes through a puddle of water. Replaced all three idler & tensioner pulleys with OEM and there is no wobble in the fixed pulleys. The belt to be replaced is a Dayco. Part number ribs and length verified to be correct. It was noiseless. Thank goodness the water pump is driven by the inner timing belt. And yes the tensioner pulley strength was verified correct by a shop.
free radical
Canada
Posted: 12/08/18 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
My Silverado is 10 years old and the belt still looks functions like new..
Have second new one just in case,but if it aint broke why change it
time2roll
Posted: 12/08/18 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
Changed my OEM at 100k and about to change again at 200k. At this rate it is really hard to test very many brands. Need the experience of a fleet manager. IMO any recognized name brand is fine.
675w Solar pictures back up
fj12ryder
Platte City, MO
Posted: 12/08/18 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
I tend to agree with that in theory, but my experience is that it will break at the most inopportune time, probably a mountain road with no shoulder and a line of traffic behind me. [emoticon]
I've used Gates brand belts for years and been happy with them.
Howard and Peggy
"Don't Panic"
azrving
Oatman
Posted: 12/08/18 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
I usually buy Gates. They seemed to be a top brand years ago but who knows what the content is now. How much water are we talking about, I mean I did hydroplane a 1959 VW and ended up on a lawn next to a huge oak tree so I just thought I'd ask. I go through water pretty slow.
Are all the plastic shields in places?
* This post was edited 12/08/18 10:08pm by azrving *
ItsyRV
Desert SW
Posted: 12/08/18 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
Gates, Dayco and Continental probably make the top belts for non specialized applications. Just be careful as they all make a range so there are low and high quality belts in their lineups. I switched to Continental's Elite due to the staggered cog configuration and alignment stable backing. I do change the belt more frequently than required, but even with it's premium $30 price, it is still pretty cheap maintenance.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
1320Fastback
Vista, Ca
Posted: 12/09/18 01:08am Link  |  Quote  |  Print  |  Notify Moderator
Gates Green Stripe Fleet Runner is all I use.
1992 D250 Cummins, 5spd, 4"' straight piped, sensors deleted, airbags, DAP injectors, 18cm.
All I could afford
North jersey
Posted: 12/09/18 07:02am Link  |  Quote  |  Print  |  Notify Moderator
Is your car running the 3.0L or 3.3L V6?
I used to see them regularly with thrown belts after going thru minimal road puddles.
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollin’ on 33’s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
path1
Varies with weather
Posted: 12/09/18 09:26am Link  |  Quote  |  Print  |  Notify Moderator
B4 retirement. Large trucking outfit I worked for had great results with gates "green stripe". Not other gates. But "green stripe". Also if you carry spare, see if you have option of "with a/c" or "without a/c". If you do, carry without a/c as spare. Reason is if a/c compressor ever freezes up you wont be stranded.
MEXICOWANDERER
Posted: 12/09/18 09:44am Link  |  Quote  |  Print  |  Notify Moderator
It's a 3.0 and yes it is a familiar PITA. Would not this have been easy to design against? Like add a 1/16th inch height to the outboard ridges of the pulleys? This is exactly the kind of stupidity I growled and snapped about a few posts ago. MoPar made an ice and snow shield to help with this problem but no one else made them and this model is a red-headed orphan with MoPar.
Mitsubishi! Original manufacturer of the self-lighting Zero fighter.
