RV.Net Open Roads Forum: Tech Issues: Winter camping at Monument Valley
 > Winter camping at Monument Valley
Kober
Arizona
Posted: 12/09/18 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Going to spend a few days in Monument Valley December/January.
Read about 25% failure rate on Camco 25 ft heated water hose. Sounds risky. Wrapping a 25ft hose with heating tape and then insulating the thing appears to be the only alternative.
Any other suggestions?
2004.5 Dodge 3500 4x4 DRW CTD 600, Warn Winch etc,
2008 FUZION 362.
PATRIOT GUARD RIDER, AMERICAN LEGION RIDER
Retired 25 years US ARMY, retired 24 years business owner
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 12/09/18 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
The only way I had success was to fill then drain the hose. Better than money spent for nothing only to end up with a split hose. Yeah it's a pain. Yeah it's winter. Better than melting snow with a campfire I guess.
Bill.Satellite
Full-timer
Posted: 12/09/18 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Right! Don't leave the hose out. Connect to water, fill, disconnect and drain hose. Rinse / repeat as necessary.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
2oldman
Ca
Posted: 12/09/18 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
ppine
Northern Nevada
Posted: 12/09/18 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
Hard to camp in MV because it is mostly Navajo Nation land.
agesilaus
North Florida
Posted: 12/09/18 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
Camp in the Valley of the Gods which is close unless you need hookups.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Kober
Arizona
Posted: 12/09/18 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Actually, I guess it would be ok to only connect when taking a shower and leave the grey open during that time. Thanks for the tips.
Bill.Satellite
Full-timer
Posted: 12/09/18 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
Does your RV not have any fresh water holding tanks? If there are grey and black tanks you should also have a fresh water tank. You can leave the grey open as long as you have a sewer hook up as you won't want to be draining on the ground in the park. Also, if you do have hookups, be sure to empty the drain hose as well as it will freeze a bit over and over and then clog.
Lone Pine, CA
Posted: 12/09/18 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
Why leave the hose out? Fill your water tank and use it. RVs don’t need to be tethered!
Winnebago 2101DS TT & 2019 Chevy Silverado LTZ Z71, 300 watts solar-parallel & MPPT, Trojan T-125s. TALL pole for flags. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
MrWizard
Traveling
Posted: 12/09/18 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
self contained RV
fresh water tank
grey water tank
fill it up , take shower
get more fresh water when needed
empty grey before leaving,
the only reason to stay connected to water and to open grey when showering
is 'on demand instant water heater' and 30 minute showers
well different strokes for different folks
but i thought RV camping people were used to being adaptable
weather is cold, skip the worry about using hoses
Radiate The Happy
1997 F53 Bounder 36s
