RV.Net Open Roads Forum: General RVing Issues: towing rates
 > towing rates
Road Phantom
pa
Posted: 12/09/18 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone know or have an idea how much RV towing companies charge per mile. Thanks.
wanderingaimlessly
Buggs Island lake
Posted: 12/09/18 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
Check this for a rough idea.
https://www.uship.com/cost-to-ship/vehicles/recreational-vehicles-rvs/
doxiemom11
Victoria TX
Posted: 12/09/18 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
They may charge more for different types of vehicles. Very common for a 4x4 having a higher charge, or for an rv.
Tal/IL
Central Illinois
Posted: 12/09/18 11:27pm Link  |  Quote  |  Print  |  Notify Moderator
Several years ago, my 33'Class A gasser had to be towed about 20 miles. Had a very difficult time finding someone to tow it and the bill was $750.
35 miles from Normal, IL. As close to normal as I'll ever be.
2006 Country Coach Inspire Genoa 40ft
valhalla360
No paticular place.
Posted: 12/10/18 12:05am Link  |  Quote  |  Print  |  Notify Moderator
Are you talking roadside assistance (aka: tow truck)
Or are you talking about someone to tow your trailer to a campsite?
Makes a big difference.
Assuming the second, start & end points and total distance make a big difference in the per mile price. A 50 mile tow from remote are to remote area will likely be much higher per mile than a 1500 mile tow from populated area to populated area.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Posted: 12/10/18 07:19am Link  |  Quote  |  Print  |  Notify Moderator
I will tell you only this. for a Big motor home (Like my 38' class A) you need a Heavy Duty (Semi size) tower.. The charge varies depending on location.. Both the "Hookup" and the millage will depend on where you are when you break down.
Plan on a thousand dollars for most tows. YOU WILL GET CHANGE BACK in all likelyhood. I have been towed 3 times and winched a few times (Stuck in sand or loose dirt) the winches were 100-250 dollars the tows ran about 800 each. One of 'em was from Savannah GA to Darien Ga. if you want to check the millage. One was from Darien (Technically Townsend twp) to a different site in the same township that one was a bit less... They only damaged one thing (Very Minor and 'nm not sure which tower did the damage.. I fixed it no charge).
BB_TX
McKinney, Texas
Posted: 12/10/18 11:42am Link  |  Quote  |  Print  |  Notify Moderator
If you are referring to ERS type towing. I had to have my truck and 5er towed about 7 years ago. I was on eastbound I-240 just east of Oklahoma City. ERS sent two trucks, one rollback for the truck and a pickup with 5th wheel hitch for the 5er. One driver took the truck about 5 miles to a dealer and the other towed the 5er about the same distance to a KOA. Wife and two granddaughters went with the first driver to the dealer. I went with the pickup driver. That driver pulled the 5er into my assigned site, waited while did basic hookups, then took me to the dealer where my truck was. Total costs was approximately $450. Probably a little higher now.
 > towing rates
