RV.Net Open Roads Forum: Toy Haulers: Axle capacities
Search only in Toy Haulers
 > Axle capacities
sandblast
salt lake city utah
Posted: 12/13/18 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
A friend is looking at a 2008 Keystone Raptor 3814SS.
After searching the Keystone archived spec`s still can not find individual axle capacity for 3814SS. Looking at gross weight divided by three axles is still a guess at best. TIA.
CALandLIN
SC
Posted: 12/13/18 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
The vehicle certified GAWRs for that trailer, with dual axles will be 7000# ea..
Using the new RVIA tire load capacity recommendations, to provide 10% in load capacity reserves per axle. The minimum tire load capacity - via inflation - will 3850# per tire.
Old-Biscuit
Verde Valley
Posted: 12/13/18 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
That trailer has a dry weight of 12,045# with a dry pin wet of 2639# (22%)
GVWR is 16,500#---wet pin roughly 3630# (12,870# on 3 axles)
Triple axle....would hope that they are 6000# but could be 5200#
(RV MFG. do not put axles rated for GVWR...they put axles adequate for weight carried by axles (minus pin weight)
Crawl underneath and look for tag on axle
Call Keystone Customer Service
Phone (toll free): (866) 425-4369
azdryheat
Tucson, AZ
Posted: 12/14/18 07:37am Link  |  Quote  |  Print  |  Notify Moderator
People forget that toy haulers aren't loaded the same as 5th wheels. As weight is added to the garage the pin weight gets lighter. My almost empty (scaled) pin weight is 3500 pounds. If I add 2000 pounds to my garage my pin gets lighter, not heavier.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
redhooker
Posted: 12/14/18 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
Also numerous toy haulers as well as standard fifth wheels have axles and tires that add up to less than GVWR. An 18k GVWR fiver might have two 8k axles. I will not own a trailer equipped like this.
deltabravo
Spokane, WA
Posted: 12/14/18 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
I guess the RV manufacturer "fudges the numbers" and says "axles don't support the entire weight, some of it his hitch / pin weight"
BAD business practice in my opinion.
2018 Timberridge 24RLS (bought pre-owned 3/12/20)
time2roll
Posted: 12/14/18 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
My GVWR is exactly the axles plus dry pin. As for the OP this is the last thing I would worry about. Never read about axle failures.
675w Solar pictures back up
CALandLIN
SC
Posted: 12/15/18 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
After looking at the specs for that 3 axle trailer and doing some math I would say it has 3 5000# axles derated to about 4700# GAWR ea. That can be verified by having someone look at the vehicle certification label found on the LH FWD external section of the trailer.
The math for determining GAWR axle loads goes like this. Subtract the trailer manufacturer's recommended tongue/hitch weight from the GVWR and divide by 3. The result is the minimum load capacity allowed for the vehicle certified GAWRs.
The following is an excerpt from the FMVSS standard the vehicle manufacturer MUST comply with.
"On RV trailers, the sum of the GAWRs of all axles on the vehicle plus the vehicle manufacturer's recommended tongue weight must not be less than the GVWR. If tongue weight is specified as a range, the minimum value must be used."
* This post was edited 12/15/18 02:18pm by CALandLIN *
Wild Card
North Carolina
Posted: 12/17/18 05:29am Link  |  Quote  |  Print  |  Notify Moderator
A trailers axles will never see gvwr. So that would make a trailers suspension more stiff and ride like ****.
2015 Ram 3500 Dually
Sundowner 2286GM Pro-Grade Toyhauler
Retired JSO
Northeast Florida
Posted: 12/17/18 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
Try crawling under and look for the tag on the axles. My old Work and Play had 5200 on the sticker on the side of the trailer. After a crawl under, discovered they were stamped 6K.
 > Axle capacities
