RV.Net Open Roads Forum: Travel Trailers: Running your propane Refrigerators while traveling?
 > Running your propane Refrigerators while traveling?
Page of 13
mobeewan
Hampton, Va
Posted: 01/02/19 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
MSchu wrote:
It says "especially in underground tunnels". Is that because propane sinks and would be trapped in the tunnel? would it be less of a risk in a mountain tunnel where one end is lower than the other?
I pulled my trailer through the tunnel in Zion NP where you have to have a permit to pass and they never even mentioned propane.
The word underground is misleading. Pretty much all tunnels are underground. Even the ones that go straight through a mountain from one side to the other are technically underground. So are the ones that go underwater. They are anchored in place with a layer of silt or sand over top of them. Whether they go straight through from one side of a mountain to another or down and then back up again like an underwater tunnel it really doesn't matter. Even if the tunnel has fans that are pulling the bad air out of the tunnel so fresh air can come in and there is an explosion there will be a fireball. That fire ball will travel in the direction the air is flowing in the tunnel.That is usually in the direction that the vehicles are traveling. This creates a blast furnace effect incinerating everything in the path of the fireball until it burns out. If the fireball is bad enough you can get a chain reaction of explosions as feul tanks from other vehicles cook off. Tunnel fires are not a very pretty sight. Even if it's just a car fire because of an engine problem or electrical problem there will be a lot of smoke created let the ventilation fans probably won't be able to keep up with.
DM6156
Georgia
Posted: 01/04/19 06:45am Link  |  Quote  |  Print  |  Notify Moderator
On a related note, at least in Georgia..
RULES OF SAFETY FIRE COMMISSIONER
CHAPTER 120-3-11
RULES AND REGULATIONS FOR FLAMMABLE AND COMBUSTIBLE LIQUIDS
120-3-11-.07 Standards for Transportation of Flammable and Combustible Liquids by other than Tank Vehicle.
Vehicles shall be in good operating condition and shall not be overloaded. Every vehicle regularly used for transporting flammable or combustible liquids shall be equipped with at least one fire extinguisher having a rating of 20-BC, permanently mounted and readily accessible to the driver.
Make sure you have the appropriate fire extinguisher.
I had to research what 20-BC meant...
https://www.bettendorf.org/egov/docs/1160167747_549163.pdf
Also, while I can't find the exact code, but there is a limit of the number of cylinders a single vehicle can transport. I have found reference to this in several places, but not found the exact number. I had a conversation with a friend who went with some buddies to local store to fill up their cylinders before a 2 week trip last fall and the rep told them they had too many cylinders by law in a single vehicle.
austinjenna
Columbus, Ohio
Posted: 01/04/19 07:01am Link  |  Quote  |  Print  |  Notify Moderator
CHAPTER 120-3-11
I would say those laws are talking about tanker trucks or trucks that carry propane bottles and such - not RV's.
There are no laws that say you cant have propane bottles on a rv-travel trailer etc.. while going through any state.
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
drsteve
Michigan
Posted: 01/04/19 08:08am Link  |  Quote  |  Print  |  Notify Moderator
CHAPTER 120-3-11
I suspect that statute applies to commercial trucks hauling cylinders of welding gas, rather than RVers.
1991 Palomino Filly PUP
tjschaefer
Jackson, Michigan, Jackson
Posted: 01/06/19 05:59am Link  |  Quote  |  Print  |  Notify Moderator
Its not propane refrigerators that start fires, its people that aren't aware of what they are doing that start fires. Common sense goes a long ways.
larry cad
ohio
Posted: 01/06/19 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Not to be disagreeable, but what lack of common sense occurs when an RVer is sitting outside of their 5 year old RV, and all of a sudden their Norcold 1200LRIM bursts into flames and totals their RV?
Please don't try to put failure of a poorly engineered frig onto the backs of unsuspecting users. Say all the bad things you want about the manufacturer, but consumers should have a reasonable expectation that RV appliances should not suddenly burst into flames and destroy their home when all the owner did was operate the appliance according to the manufacturers instructions.
Our Travel Blog
pianotuna
Regina, SK, Canada
Posted: 01/06/19 07:59am Link  |  Quote  |  Print  |  Notify Moderator
Larry Cad,
Well said! Flu temperatures of 700 degrees are stupid design and have nada to do with operator error.
Regards, Don
drsteve
Michigan
Posted: 01/06/19 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Many of the problems are due to improper installation by the RV manufacturers.
aftermath
Washington State
Posted: 01/06/19 09:35am Link  |  Quote  |  Print  |  Notify Moderator
This has nothing to do with the OP's original question. He asked about safety concerns regarding running down the road with the propane fridge on. Again, please offer up one, just one, case where this has happened. If the fridge you described did indeed spontaneously combust while parked in a campground it really isn't applicable to the discussion. Using logic here, your story would let people believe that you shouldn't have a fridge at all!
2017 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
Crabbypatty
Long Island, New York
Posted: 01/06/19 11:39am Link  |  Quote  |  Print  |  Notify Moderator
For 14 years in two different TT's. the only time we turn it off is tunnels. There is something with the extra pressure of going under water that might cause a problem otherwise its on from the moment we disconnect n the driveway until we get where we are going. From the Maine to Fla. Thousands and thousands of miles and never a blip.
Happy Trails
John, Lisa & Tara">">">
2015 F250 4x4 Platinum, 6.2L 6 spd 3.73 gears, Reese 12klb w/dual cam, Prodigy, Sunny Brook Sunset Creek 298 BH, Trojan 125's, 448 watts Solar Morning Star 45, Honda EU3000, Dish TV, Xantrax Pure Sine 2000, Wilson Cellular Ant/Amp
Page of 13
