RV.Net Open Roads Forum: Travel Trailers: 2018 flagstaff superlite has condensation on walls
 > 2018 flagstaff superlite has condensation on walls
Rodney j callahan
Louisiana
Posted: 12/20/18 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
I have a problem with condensation forming on walls where the frame work is,all corners.we live in this thing for weeks at a time during winter and when we heat it up here come the condensation, has anyone found a fix for this thanks,also i dont have access to electricity 24/7 so a dehumitifer is not an option,lookin for other options thanks
pianotuna
Regina, SK, Canada
Posted: 12/20/18 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Welcome to the forums!
What to do about condensation?
The cause of the condensation is the walls are below the dew point temperature. If the walls can be made warm enough the problem disappears. Running a fan to circulate air may help to raise the temperature on the surface of the wall.
One other solution is to reduce the relative humidity inside the RV.
The easiest way to do that is to open a roof vent a bit, find the furthest window from the vent and open that a bit. An electric heater near the window will improve that and keep you warmer. I'd suggest a low wattage radiant type, or a small oil filled (if the oil filled can be on a shelf so the air from the window passes over the fins.)
I know opening a vent and window when it is cold seems counter intuitive, but it does work.
Another possible solution is an electric dehumidifier--but the cooler it is the poorer they work. They are generally energy hogs, some what bulky and definitely noisy.
The above is from this series of posts under full time RV'ing:
https://forums.goodsamclub.com/index.cfm/fuseaction/thread/tid/24160748.cfm
I suggest reading it soon!
Regards, Don
downtheroad
Pacific Northwest
Posted: 12/20/18 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Very common and normal when living in a box that has 2" think wall....in the winter.
pianotuna above has some good solutions.
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
donn0128
Pronounced Ore-gun
Posted: 12/20/18 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
Get and use a BIG dehudifier
SoundGuy
S Ontario
Posted: 12/20/18 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
The OP said - "also i dont have access to electricity 24/7 so a dehumitifer is not an option".
Just people breathing inside a closed up camper will create condensation so ventilation is a must.
2012 Silverado 1500 Crew Cab
2014 Coachmen Freedom Express 192RBS
2003 Fleetwood Yuma * 2008 K-Z Spree 240BH-LX
2007 TrailCruiser C21RBH * 2000 Fleetwood Santa Fe
1998 Jayco 10UD * 1969 Coleman CT380
Crestview area, Inyo County, California
Posted: 12/20/18 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Condensation is your doing, not the RV’s doing. Open a window, buy a dehumidifier regardless of your electricity issue, lower the indoor temperature etc. An RV isn’t a stick and brick.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
mobeewan
Hampton, Va
Posted: 12/20/18 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
Things inside a TT that produce water vapor.
Exhaling - the human body expels water vapor while breathing. You can produce a quart or more of water vapor just while you sleep. So figure one person can produce 3 or more quarts per day.
Cooking - moisture boiled off while cooking either in the oven or the burners on top of the stove. Propane combustion also gives off water vapor as a byproduct of combustion. All microwaves are vented at the top rear of the cabinet. Although they are usually mounted over the stove hood in trailers they are never vented by the stove exhaust fan. The microwave exhaust usually winds up coming out of the grill at the front top of the cabinet enclosure the microwave sits in.
Propane heaters - Mr Buddy, Wave 3, etc all will add to the humidity level due to combustion.
Showering - hot water and cool air means more humidity.
I normally kept both roof hatches cracked about an inch. When it was too breezy or cold and I had to close the front hatch I ran a 25 pint per day whirlpool humidifier set at 40 percent humidity. That was suitable for me and one Chihuahua in my 28-1/2 footer.
colliehauler
Mc Pherson KS USA
Posted: 12/21/18 09:30am Link  |  Quote  |  Print  |  Notify Moderator
You can open the rv vents and windows for ventilation or get electric power and a dehumidifier or move to a drier climate.
* This post was edited 12/21/18 09:37am by colliehauler *
delwhjr
TX
Posted: 12/21/18 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Check out the Eva-dry renewable dehumidifier. This is a renewable item which will dehumidify and then you can restore it to work again. It does not use electricity to remove but uses a little to renew. There are different sizes for large and small spaces.
2019 F250 Crew 4x4 6.2
2019 Rockwood UltraLite 2608BSD
CFerguson
on the road
Posted: 12/21/18 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
+1 on this product. Works better than a typical dehumidifier.
