RV.Net Open Roads Forum: Travel Trailers: 2018 flagstaff superlite has condensation on walls
 > 2018 flagstaff superlite has condensation on walls
ktmrfs
Portland, Oregon
Posted: 12/21/18 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
Let's assume the OP had electricity for say 6 hrs/day. running a compressor driven dehumidifier for that length of time will likely solve the condensation problem. It may take a few days but should help a great deal. Mine will often pull 2.5 gallons out of the air in 6-8 hours. Once it gets the humidity down to the 50% range or so, it pulls out about 2-3 gallons/day.
Long term use in other than a very dry climate IMHO pretty much means measures to prevent moisture buildup. In moderate humidity climates, opening windows, fans on etc. when cooking, showering may be enough. But when humidity rises outside and/or it gets cold at night, that is often not enough and a compressor driven dehumidifier is appropriate.
IMHO the peltier devices or damp rid type are fine for storage, but can't pull near enough moisture out when trailer is in use.
2011 Keystone Outback 295RE
smthbros
WI
Posted: 12/23/18 10:09am Link  |  Quote  |  Print  |  Notify Moderator
As the temperature difference between indoor and outdoor air increases, so too does the dehumidifying effect of ventilation.
Rodney j callahan
Louisiana
Posted: 01/01/19 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the information on condensation in camper,will invest in dehumidifer that can run on generator
colliehauler
Mc Pherson KS USA
Posted: 01/01/19 10:59pm Link  |  Quote  |  Print  |  Notify Moderator
Probably a wise decision although expensive one.
The odd thing is I have to run a humidifier of a winter in Kansas and a dehumidifier if I winter in Florida.
PAThwacker
East Stroudsburg, PA
Posted: 01/03/19 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Is this your first time owning a camper? How cold is the area you are in? In the mid-atlantic we get serious condensation in the spring and fall.
2007 R-Vision Trail Sport 26-QBS
2007 Jayco 1206 Pupup
2004 k2500 Suburban LT 6.0/3.73 Captains.
Lowe Bass Catcher Pro Mod-V Welded 50hp Mercury
Bell Chestnut Prospector 16ft Royalex
Kawasaki Prairie 360 4x4 Camo
Rodney j callahan
Louisiana
Posted: 01/10/19 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
I have had campers for along time and this is my first fiberglass sided camper, when it sweats i can see where it collects where the frame work is in the walls wherw thete is no insulation
